power saddle specialized 143 or 155mm version?
dedobike
by dedobike
They are undecided on the width of the specialized power saddle.
My width of sit bones is 121mm which version should I take? 143 or 155mm?
zefs
by zefs
Based on Specialized chart you can use both so it probably depends on what position you are using, more aero or more upright?
dedobike
by dedobike
But I knew that for the saddle power is another scheme that suggests to take a size more than a classic saddle for example if you use a romin 143mm you have to choose a power 155
Inviato dal mio M5c utilizzando Tapatalk
zefs
by zefs
Could be, I couldn't find any charts that include the power saddle, but maybe you could ask a specialized dealer about that.
tabl10s
by tabl10s
I had both on two bikes with no problems(S-Works).
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
