Understated bar / stem / post combo
powergoose
by powergoose
Hi all
I'm building up a new bike and am looing for an understated bar / stem / post combo. Ideally as plain/black as can be - its a deep grey F&F and I don't want to spoil it with a load of flash logos. The Enve kit is beautiful, but i'm not sure I can stretch to £250 a pop!
Any ideas gratefully received.
Dom
Zakalwe
by Zakalwe
Any black alloy finishing kit you like, with the decals removed with acetone
ChiZ01
by ChiZ01
3T Team Stealth is good value / performance for stem and post
robertbb
by robertbb
Zakalwe wrote:
Fri Jan 25, 2019 12:01 am
+1
powergoose
by powergoose
How's that done then??
powergoose
by powergoose
....oh, and i'm looking for a carbon post and bar!
Zakalwe
by Zakalwe
You just get some nail polish remover - make sure it contains acetone, as some are marketed for sensitive skin and use a different solvent - and rub the decals off any alloy parts. Decals on carbon are usually applied under clearcoat, so this is an alloy only trick. For Carbon you have to sand the clearcoat off.
As for understated carbon, Ritchey Superlogic parts are pretty low key
Miller
by Miller
The acetone thing, I did that on a Kalloy Uno stem. The logo came off easily enough but it left a faint impression that would not shift. Still, the stem looked unbranded at first glance.
Zakalwe
by Zakalwe
For really stubborn decals I soak a bit of cotton wool and tape it over the spot, then leave it for a while to work it’s chemically magic
