36cm handlebars
CavBannas
by CavBannas
I was just wondering if anyone has come across a set of 36 or 38cm handlebars woth a flat/aero top on them. Thanks
dudemanppl
by dudemanppl
No 36 (unless you count ENVE SES), but for 38 theres a decent amount of options:
Zipp SL70 Aero
Bontrager XXX Aero
Deda Superzero
S-Works Aerofly II
none
by none
FSA used to have a K-wing that's 36cm wide.
You can probably use carbon track handlebars that have 38 or 36 width, likely they won't have internal cable route.
DartanianX
by DartanianX
Specialized do a women’s bar.
My other half has some and loves them! 70mm reach and shallow.
icantaffordcycling
by icantaffordcycling
I was looking at 3t Aeronova Teams but ended up going with cheaper aluminum bars from Bontrager with a top flat section. They are called "Bontrager Elite Aero VR-CF Road Handlebar" in 380mm and I like the internal routing on them. On my track bike, I have Specialized Womens Shallow Bend ALU bars in 36cm but even the S-Works version does not come with flat tops.
