2019 Colnago C64 Disc Build - Actual Weights
ymisyd
by ymisyd
Hello,
Here are some actual weights from my self-build C64 Disc 52S PJRD. Any questions about the weights or build, please ask. I'll be fitting Roval CLX 50 disc wheels which should arrive next week.
C64 Disc PJRD 52S Frame (with headset bearings, without BB) 1082g
C64 Disc fork (uncut steerer) 475g
C64 Seatpost 210g
11-28 DA cassette 197g
DA 11 speed chain (uncut) 255g
Shimano E-tube handlebar junction 20g
50/34 DA chainset 172.5mm 652g
DA 9150 front derailleur 104g
DA 9150 rear derailleur 197g
Colnago SR9 stem 169g
Colnago R41 bars (40cm) 219g
Hutchinson Performance 11 Storm 25mm tyre 238g
DA Di2 shifter left 161g
DA Di2 shifter right 161g
DA 9170 front caliper 115g
DA 9170 rear caliper 115g
DA 160mm rotor (with lock-ring) 138g
DA 140mm rotor (with lock-ring) 117g
Di2 internal battery 56g
Saddle S-Works Power 143mm 159g
Bar tape Fizik superlight (no bar end caps) 75g
Bottom bracket - Ceramicspeed 103g
Di2 cable - Y-split 350/50/450 9g
Di2 Junction B SM-JC41 4g
Di2 cable 1200mm 11g
Di2 cable 1000mm 10g
Di2 cable 650mm 6g
Di2 cable 300mm 3g
Hydraulic hose 1000mm (uncut) 28g
Hydraulic hose 1700mm (uncut) 42g
DA pedals 248g
Colnago bottle cage 30g
Front supplied axle 27g
Rear supplied axle 33g
Roval CLX 50 disc front (with valve and rim-tape) 642g
Roval CLX 50 disc rear (with valve and rim-tape) 771g
ducman
by ducman
Estemated total?
ymisyd
by ymisyd
ducman wrote:
Tue Jan 15, 2019 6:23 am
Estemated total?
I'm hoping for 7200-7300g on the road (cages, computer mount etc.). Should know for sure by the weekend.
