Stem -10 degree, 110mm, sub 120g, sub $50-60 ?
Radiokopf
by Radiokopf
I have the UNO 7 Stem. 20€, 108g.
Gesendet von iPhone mit Tapatalk
KarlC
by KarlC
shimmeD wrote:
Wed Jan 09, 2019 1:22 am
Beware, the stack height you refer to on the Deda may actually be the clamping stem-to-steerer only. In my experience I moved from a Ritchey (42mm) to a Thomson (36mm) with no difference in handlebar height. The 6mm difference was taken off the top of the stem clamping.
I can confirm that the Deda Superleggero -8 Stem and the FSA SL-K -12 Stem both have a total stack height of 34mm vs other stems that are in the 40mm range
StanK
by StanK
I think shimmeD is referring to the height of handlebar. Meaning, doesn't matter that Deda has 6mm lower stack height than others (34mm vs. 40mm) - both placing handlebar on same distance from the ground. That is what actually interested me.
If Deda, with 6mm lower stack height, doesn't put handlebar 3mm lower (let's say 3mm "less material" from up and down of stem), then it doesn't really matter to me. And in that case -10 degree stem would be more interesting option.
StanK
by StanK
Radiokopf wrote:
Wed Jan 09, 2019 3:36 pm
If you can find me one with -10 degree, I'll buy it. Immediately.
More so, I will also buy one with -8 degrees, 110mm, so I will have 3 stems to play for at least a month. :mrgreen:
KarlC
by KarlC
I'll like to find a -10 degree stem that is round and has a short stack.
The Pro PL is -10 and nice but its not a short stack and is a hexagon shape that does not go well with round frame tubes to my eye.
Imaking20
by Imaking20
Why the requirement for a short stack on the stem?
Stormy SL6
Hakka MX
Retired:
Acid Mint Tarmac|Boone|Wilier Wonka|The Dentist|The Bucket List|Evo|T2|Blue|Project C6.0|Felt AR FRD|Colnago C59|S-Works Tarmac SL4|S-Works Venge|Wilier Cento1 SL|Tarmac SL2
KarlC
by KarlC
Imaking20 wrote:
Wed Jan 09, 2019 10:19 pm
My new project has a bit taller Head Tube than I like, so I installed a Extralite UltraTop Headset. The UltraTop dropped it about 10mm vs the Chris King head set, then I used a Deda Superleggero Stem 120 -8 stem that has a 34mm stack. The 2 together droped it about 16mm.
https://weightweenies.starbike.com/foru ... 0&t=154922
Imaking20
by Imaking20
Gotcha. I didn't think the stack height of the stem was additive to the frame stack like that. I had always figured 8* was 8*
Stormy SL6
Hakka MX
Retired:
RocketRacing
by RocketRacing
Wren. -6 or -17 degree, sub 100g, and 50$ or so
StanK
by StanK
Does anyone have -10° stem on bike with 12° (11-13 is fine, too) slope top tube? Pics would be much appreciated. :D
I try to figure out will it be (for me) visually ok, or would be too much "down", "broke down" look.
For my calculation, -8° stem would be in line with top tube, but ... some extra drop of handlebar (no spacers left) would be welcomed. So ...
jencvo
by jencvo
dolile wrote:
Tue Jan 08, 2019 6:05 pm
I have been running a Lity 100mm 6° stem (97gr) for 2 years, it is actually an excellent stem and I pay 39 euros for it.
Where did you get those from? I don't know if it's due to Sunday morning and lack of coffee or what but google search returned nothing...
wheelsONfire
by wheelsONfire
jencvo wrote:
Sun Jan 13, 2019 1:54 pm
https://www.dulight.fr/en/115-stems
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
RocketRacing
by RocketRacing
StanK wrote:
Sun Jan 13, 2019 1:36 pm
-17 on my bike is flat to the road. Never much thought of the asthetics of it. More aero.
halcyongolf
by halcyongolf
Older model Eason EA90 with ti bolts should be around that weight and under that price (on sale). I picked up a -10* EA90 for under 30 bucks.
simoncx
by simoncx
halcyongolf wrote:
Tue Jan 15, 2019 2:24 am
I was going to say the same thing, I had a -10 ea90 in 120mm and it was 142g without ti bolts.
