Best aftermarket crankset for Etap?
spdntrxi
by spdntrxi
I ran etap with praxis rings (thm cranks).. worked well. buzz and older clover rings
tabl10s
by tabl10s
wheelsONfire wrote:
Sun Jan 06, 2019 1:24 pm
In short, what is the best aftermarket crankset for Sram Etap?
Fast and precise shifting.
I use Clavicula SE on two bikes.
2016 Orbea Orca OMR: 15.0lbs/6.804kg...😐 | 2016 Rca: 11.07lbs/5.048kg...😭 | 2015 Pinarello F8: 13.04lbs/5.915kg...😩 | 2018 S-Works SL6: 12.04/5.625kg... 😥
spud
by spud
I don't ride etap, so my comments can be discounted but...I've had very good success with Campy cranks. Current favorite is the old model Super Record with CULT bearings, which resist corrosion and have given me many miles with no noises and very easy servicability etc. Old model can be tracked down for not a ton of $
DJT21
by DJT21
jeanjacques wrote:
Sun Jan 06, 2019 11:37 pm
Marin wrote:
Sun Jan 06, 2019 11:02 pm
Also, the Red crank is one of the lighest cranks out there.
Not the BB386 the OP have. Around 630g no ? Aldhu DM can be slighlty lighter, around 10g.
I think they're under 600g?
wheelsONfire
by wheelsONfire
Nope, i have the specified BB 386 which also have a removable spider.
I ordered crank separate, after looking into warranties with Sram.
However, i noted that chain easily drop inbetween big/small shifting down from 50 to 36 while in 11th gear.
I played around a bit with 0.5 washers, but it didn't solve the issue.
FSA K-Force Lite have much better chainring ramps, also Wickwerks which sadly doesn't sell 50/36 combo.
THM is a beautiful crankset, not sure i would dare use it with Sram Etap though!
I would get serious anxiety if the chain jumped outboards leaving a ugly mark in this crank.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
