Road disc; centerlock or six bolt?
hannawald
by hannawald
Shimano has governed the road disc market so standard choice is centerlock. But if you want light disc project (I know contradiction:) than go 6 bolts, much lighter. You can have hubs from Extralite or Tune or Carbon Ti... rotors from Galfer for example. Weight difference is significant, there really is not a rotor choice in centerlock..
Both systems works well.
SchallUndRauch
by SchallUndRauch
I prefer centerlock for ease of changing rotors and taking them off for travelling. With an adapter, you can still use the cheaper 6-bolt rotors. In contrast to hannawald, I find the bit of extra weight not to be significant, but my approach is less governed by grams.
RocketRacing
by RocketRacing
6 bolt give you the weight weenie options. But dt swiss makes a great centerlock to 6bolt adaptor.
Given the choice, i would do 6 bolt, but i have a torque wrench.
martinkartin
by martinkartin
I would rather use center lock based on aesthetics of the hub and the locking ring, but the 6 bolt option will be on my next wheelset as ww hubs are apparently built lighter not having the center lock spline.
Factor O2 Disc Romain Bardet Limited Edition
maxxevv
by maxxevv
NickJHP wrote:
Fri Jan 04, 2019 2:14 am
TobinHatesYou wrote:
Fri Jan 04, 2019 1:08 am
If you travel with your bike, choose centerlock hubs/rotors so you can remove the rotors easily.
Except that then you need to also travel with the appropriate lockring tool and a minimum 8" wrench to get sufficient torque when installing the rotor. For the six bolt rotor all you need is the Torx or allen key.
Sounds like you have never dabbled with removing/replacing your wheelset cassette before ?
NickJHP
by NickJHP
maxxevv wrote:
Sun Jan 13, 2019 5:24 am
Not outside of my workshop, no. When I'm travelling by bike, I just carry a minimal set of tools. I haven't broken a spoke since I started using stainless steel spokes about 40 years ago, so I don't bother to carry a lockring remover or the wrench and chainwhip needed to use it.
TobinHatesYou
by TobinHatesYou
NickJHP wrote:
Thu Jan 24, 2019 2:47 am
You don't need to use a chainwhip to remove a rotor...
Zakalwe
by Zakalwe
You do for the cassette removal in question
maxxevv
by maxxevv
Zakalwe wrote:
Thu Jan 24, 2019 8:04 am
It was alluding to the fact that its just the same tool used for a centerlock rotor lock ring as a cassette one.
TobinHatesYou
by TobinHatesYou
And this is still a thread about rotors. I brought up centerlock for travel because I really couldn't be arsed constantly loosening/fastening 12 bolts every time I moved from one travel stop to another. I'll take the weight penalty of carrying a simple one-piece lockring tool like the one Abbey Tools makes.
maxxevv
by maxxevv
Thu Jan 24, 2019 10:10 am
Agreed. Not forgetting that the much higher torque specifications of a single lockring means that a torque wrench is mostly moot. Not that much so with the 6 bolts due to its more sensitive, lower torque values.
Miller
by Miller
maxxevv wrote:
Thu Jan 24, 2019 9:41 am
As I found recently, not necessarily. The dimensions of some hub axles preclude use of a CL lockring that is tightened with a cassette tool. For hubs with oversize axles you need a CL lockring with external splines like Shimano SM-HB20. These are fastened with the tool used for external BB cups.
Zakalwe
by Zakalwe
Yeah, Campy discs use the BB cup tool rather than a cassette tool
FIJIGabe
by FIJIGabe
Zakalwe wrote:
Thu Jan 24, 2019 2:22 pm
So do my Bontrager Affinity Comps. Odd, because every other Centerlock wheelset I have uses the cassette tool.
Emonda SLR https://bit.ly/2UK5FP8
Crockett, Madone 5, Cobia. I own a lot of Treks.
kode54
by kode54
Centerlock. Less things to go wrong or bad. Saves time. Looks better/cleaner.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
