Road disc; centerlock or six bolt?
sfo423
by sfo423
What is the verdict on choice for road?
I am looking at a new build, likely eTap. It appears the Centerline only comes in 6 bolt? The X-Rotor looks to be available in both.
There are aftermarket options too.
bm0p700f
by bm0p700f
the hubs determine the rotor.
MichaelB
by MichaelB
bm0p700f wrote:
Fri Jan 04, 2019 12:46 am
Yep, but if you get the choice, go centrelock - makes life easier & neater
TobinHatesYou
by TobinHatesYou
If you travel with your bike, choose centerlock hubs/rotors so you can remove the rotors easily. Otherwise 6-bolt has fewer clearance issues with flat-mounts, especially those on the forks.
For example my White Industries CLDs used 15/20mm lockrings (Shimano BB tool type) and those would not play nice with my Emonda SLR's fork. I had to get White Industries to send me a revised axle/endcap that would allow me to use the regular QR/12mm lockrings instead. Admittedly this is an oversight on White Ind's part, but it's a thing that happened.
silvalis
by silvalis
centreline X comes in centre lock
Chasse patate
sfo423
by sfo423
I’d be looking at flatmount.
NickJHP
by NickJHP
TobinHatesYou wrote:
Fri Jan 04, 2019 1:08 am
Except that then you need to also travel with the appropriate lockring tool and a minimum 8" wrench to get sufficient torque when installing the rotor. For the six bolt rotor all you need is the Torx or allen key.
Bigger Gear
by Bigger Gear
If you are going to have multiple wheelsets then I think 6-bolt is maybe a bit better since you can easily space the rotors so you don't have to adjust the caliper position when switching between wheelsets. I have both King R45 and DT 240S hubs in centerlock and the rear hubs play nice in terms of spacing but on the front I have to adjust the caliper position when I swap wheels. Not the end of the world, but with 6-bolt it could be seamless.
TheRich
by TheRich
Bigger Gear wrote:
Fri Jan 04, 2019 2:56 am
There are centerlock shims.
https://www.boydcycling.com/shop/access ... im-4-pack/
spdntrxi
by spdntrxi
I have 4 sets of wheels... all centerlock with different hubs .. so far I'm lucky.
Enve 4.5AR - industry9 hubs
HED Ardennes - HED hubs
Enve 5.6 - DT240 hubs
Roval CLX50- Roval hubs
TobinHatesYou
by TobinHatesYou
NickJHP wrote:
Fri Jan 04, 2019 2:14 am
There are really no side forces to worry about, so you don't have to go to the insanely conservative 40n-m recommended torque. The lockring is not going to back out.
https://www.abbeybiketools.com/products ... =242364892
I'd much rather pack this tool than waste time with 12 bolts. For a non-travel bike, I don't care...both interfaces have pros and cons.
sfo423
by sfo423
This is not a situation where I will be swapping wheels: one set and done.
Which set up stays centered in the caliper better (therefore quieter)?
TobinHatesYou
by TobinHatesYou
sfo423 wrote:
Fri Jan 04, 2019 7:02 am
Once mounted, neither is better than the other unless your bolts are backing out.
vanmatthew
by vanmatthew
Centerlock. Much easier for me. 5 less things to torque to spec.
moonoi
by moonoi
Otherwise 6-bolt has fewer clearance issues with flat-mounts, especially those on the forks...
Funny you say that, because I had the exact opposite problem on my Concept Disc, the bolts on the rotor would hit the inside of the fork where the flat mount disc caliper is mounted when sprinting, so had to rebuild the wheel with a centerlock hub to get better clearance. So now I run both...6 bolt on the rear, centerlock on the front, mainly because I was too cheap to swap out both hubs :)
