THM Tibia
tabl10s
by tabl10s
cycleboyco wrote:
Tue Jul 16, 2019 9:55 pm
wheelsONfire wrote:
Tue Jul 16, 2019 8:43 pm
Noted the bolts are not pointing straight forward, what garmin mounts are you using for Tibia?
I am using an older version of this Bar Fly direct mount stem with my Tibia:
https://barflybike.com/collections/road ... ace-direct
Even though it is not listed as a compatible stem on the Bar Fly site, the instructions that came with the Tibia notes that it is compatible with this mount and it has worked fine. I was not crazy about it at first because it's not very light (can't remember the weight off the top of my head, but it was heavier than my K-Edge race mount) and it is designed to accomodate the larger computers, so there is a gap between the stem and my Edge 820/Wahoo Bolt. It has grown on me, as it keeps the handlebar clean (I use the Di2 climbing shifters next to the stem) and Bar Fly provides both a Garmin and Wahoo mount that can be easily switched out.
Pics?
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
wheelsONfire
by wheelsONfire
Interesting, what is the weight for this mount?
Not asking you to take it off though!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
cycleboyco
by cycleboyco
wheelsONfire wrote:Interesting, what is the weight for this mount?
Well, it’s kind of fun to take things off to weigh them. Looks like 42.5 grams.
cycleboyco
by cycleboyco
Pics?
Like I said, dislike the gap from the stem to computer for the smaller computers, but have gotten used to it and probably looks fine with the larger Garmins.
tabl10s
by tabl10s
The Enve version is all metal. I hope this is lighter.
2018 Rca.
wheelsONfire
by wheelsONfire
cycleboyco wrote:
Thu Jul 18, 2019 4:08 am
Pics?
It seems a bit heavy for that stem. Kind of counterproductive. I even think a bar mounted version would be a better option. That is if weight alone is the desired prio 1.
I have F3 mount, with an addition of 2 ti-bolts (35mm * 2)
https://f3cycling.com
Which weight less (still not light)
Bikes:
Ex bike; Vial EVO D
