THM Tibia
bryanhayes
by bryanhayes
Happy New Year's WW's!
I searched and only found a little info on the THM Tibia stem.
Wondering if any of you all have one or have used one in the past and what your thoughts are about them...
I'm actually not too concerned with trying to get the lightest stem, but I would like a good looking carbon stem. The Tibia looks great to me, but I really don't want to get in a situtation were the stem is a weak point on the bike... ie - I'd rather not do a faceplant just to look cool!! :)
Let me know what your thoughts are...
Thanks!!
Seedster
by Seedster
I only know a few people with it. They have multiple bikes and only ride the Tibia part time. So far, so good. He has all his teeth and has no complaints about stiffness.
The stem feels scary light, but I am sure its safe. If it werent squared in shape, I would try it out. How much do you weigh?
Seedster
by Seedster
ignore
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
I’m 85kg and have been using one for around 3 months. No issues, and no reason to fear it - in fact, for some reason, I feel more confident with it than I did with my old Mcfk; but that’s probably more to do with me having gotten used to über light kit than any issues with the Mcfk stem.
I found I needed some carbon paste on the steerer initially, but I think they’ve updated their torque specs on the Tibia so it’s less of an issue now.
ride1970
by ride1970
I’m 70kg and have no issues with it. Feels very stiff and unreal how light it feels
mike
Resident Pro
by mike
the tibia is first rate. not the lightest but very strong.
Broady
by Broady
Been thinking about the Tibia myself, really like the look of it. Pricey but justifying the cost with the fact I haven't bought anything expensive for well over a year so I'm due something nice.
tabl10s
by tabl10s
Have three with the fourth arriving today.
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
bryanhayes
by bryanhayes
Thanks for the replies guys. I'm around 68kgs, so no heavy weight sprinter, but I don't want something that can't take some abuse. Still undecided what to do, but if I end up with one I'll be sure to update this thread.
Thanks again!
tabl10s
by tabl10s
mike wrote:
Wed Jan 02, 2019 2:44 pm
What's lighter?
2018 Rca
Klaster_1
by Klaster_1
tabl10s wrote:
Fri Jan 04, 2019 7:04 pm
What's lighter?
ax-lightness Rigid, Extralite Hyperstem. New Darimo stem might become available this year too, but no info on it yet.
NiFTY
by NiFTY
Having seen the thm crank tests (fairwheel) and having a thm ulna (mega stiff) i have no doubt the performance of this stem will be world class ( esp vs other weenie stems. The issue is i don't think there are many bikes it would go with appearance wise.
wheelsONfire
by wheelsONfire
The boring is that none of these exist in -10 / -12.
Darimo will also be -6.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
wheelsONfire
by wheelsONfire
Noted the bolts are not pointing straight forward, what garmin mounts are you using for Tibia?
Bikes:
Ex bike; Vial EVO D
cycleboyco
by cycleboyco
wheelsONfire wrote:
Tue Jul 16, 2019 8:43 pm
I am using an older version of this Bar Fly direct mount stem with my Tibia:
https://barflybike.com/collections/road ... ace-direct
Even though it is not listed as a compatible stem on the Bar Fly site, the instructions that came with the Tibia notes that it is compatible with this mount and it has worked fine. I was not crazy about it at first because it's not very light (can't remember the weight off the top of my head, but it was heavier than my K-Edge race mount) and it is designed to accomodate the larger computers, so there is a gap between the stem and my Edge 820/Wahoo Bolt. It has grown on me, as it keeps the handlebar clean (I use the Di2 climbing shifters next to the stem) and Bar Fly provides both a Garmin and Wahoo mount that can be easily switched out.
