KMC X11SL vs DURA ACE 11 CHAIN
RamirezB
by RamirezB
Hi, recently I've been building a Bianchi frame, with some good components. I have installed a Dura Ace 9000 group, a Ultegra 8000 crank and a Campy Super Record cassette, but I need a new chain. What would you recommend? (I thought of a KMC x11sl Golden, but I'm not sure)
CLEAR
by CLEAR
If you must have gold colored chain.. then KMC it is... i have mine on full campy with no issues for years. Otherwise ultegra 11 chain or xtr/da ia the way to go. I had problem with kmc on DA crankset. Not so much on the DA cassettes but i noticed kmc chain was noisier on DA full group compared to shimano chains
pdlpsher1
by pdlpsher1
Here in the U.S. the Dura Ace is much cheaper than the KMC chain. I buy them for $35. I don't know how much it costs in your country.
https://www.excelsports.com/main.asp?pa ... 1&minor=11
happyon2wheels
by happyon2wheels
I have swapped between both chains on an otherwise DA 9000/9100 setup. Functionally I cannot tell them apart except for the KMC being slightly more noisy. I mostly use the KMC as it is cheaper than the DA chain.
1415chris
by 1415chris
Of these two, KMC, should last longer and unlike DA it doesn't rust ;)
TobinHatesYou
by TobinHatesYou
pdlpsher1 wrote:
Sun Dec 30, 2018 6:02 am
https://camelcamelcamel.com/KMC-X11SL-S ... B00H2H4TIS
KMC X11SL chains in silver and gold are often $38 on Amazon. I just buy a few at a time when that happens.
C36
by C36
If I recall properly, friction fact measured he Dura ace chain with a better efficiency than any other (but possible it was one or two generation of chains back...)
Johnny Rad
by Johnny Rad
I’m a happy, long-time KMC rider. They’re quiet and haven’t rusted on me!
I haven’t run a Shimano (or SRAM) chain in years, so I have no first-hand knowledge of all this mind-blowing stuff...
happyon2wheels wrote:
Sun Dec 30, 2018 11:27 am
I have swapped between both chains on an otherwise DA 9000/9100 setup. Functionally I cannot tell them apart except for the KMC being slightly more noisy...
Wow. The KMC is noisier? I’ve read for years that KMC is quiet(er).
1415chris wrote:
Sun Dec 30, 2018 1:15 pm
Rusty chains?! Seems I’m way out of the loop on my chain knowledge.
