Thin headset spacers to match Cannondale stem
jencvo
by jencvo
Hi guys, I've got a bit of a weenie issue. Had some headset spacers laying around and used them for the new bike build. However, you can see it looks awful. Does anybody have any suggestions on what spacers to get that will match the thickness of the Cannondale stem? Every spacers I come across on the web look equally thick to what I have on right now. Thanks!
kode54
by kode54
Point 1 spacers from Toronto Cycles.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
NickJHP
by NickJHP
Moots and Seven both make Ti headset spacers...
jencvo
by jencvo
NickJHP wrote:
Sun Dec 30, 2018 8:03 am
Thank you both!
tommasini
by tommasini
ive occasionally gone into several local shops and ask if I can dig around in their spare spacer bin.......at one of them I have found a few that were 33 to 34mm outer diameter - very trim appearance. Sorry but I have no idea what brand bike they may have come off of - except to note that the dealer I found these at is primarily a Giant and Felt dealer.
flying
by flying
Hi jencvo
Did you ever get this sorted?
I know the problem as I usually run the thinner spacers as they also line up with Kalloy stems
I think the diameter is 32mm like This Deda example shows
https://www.chainreactioncycles.com/us/ ... prod158496
But many these days are 34.4-35mm
I am also hunting for a few 5mm stack of these smaller spacers myself :D
