Remove waterslide decals from DT Swiss rims
Greenduck
by Greenduck
Hi all,
I own a pair of DT Swiss PRC 1400 Spline wheels. They have minimal graphics but I would like to have them even more stealth so they only have the two DT Swiss logos. I want to remove the "PRC 1400 Spline" text.
DT Swiss use heat treated waterslides so a hair dryer will not work so I'm probably left with some kind of solvent but obviously I won't do anything which can damage the carbon rims.
I read somewhere about a person who used toluene but that was on aluminium rims.
Does anyone know if toluene will damage the rims?
Pinarello Dogma 65.1 Think 2: viewtopic.php?f=10&t=139324
ParisCarbon
by ParisCarbon
Is there any clearcote over top? If so they only way you're gonna get at it is by sanding the clear off...
Acetone is recommended by ENVE for removal of tubular glue from rims...
bm0p700f
by bm0p700f
Dont use toulene. It is the kind of solvent that could affect the resins. The only way to remove water transfer decals is to scrap them off. They are chemically bonded to the rim.
bm0p700f
by bm0p700f
Why buy branded rims if you dont want the branding. If you bought DT Swiss rim because you thought they are magically better than some of the unbranded ones from china or taiwan your are sadly mistaken.
CAAD8FRED
by CAAD8FRED
bm0p700f wrote:
Sun Dec 30, 2018 5:11 pm
Are Chinese wheels just as aero as DT?
Greenduck
by Greenduck
I want to keep the DT Swiss logos so I don't mind the branding. I just want them to have a simpler look. I will stay away from toluene as my initial thought was it could affect the resin.
Greenduck
by Greenduck
Deleted, double post
Noctiluxx
by Noctiluxx
I feel better purchasing a wheel from a highly respected manufacturer like DT Swiss than some guy assembling Chinese rims out of his garage. But that's just me.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Giant Revolt Advanced 0
bm0p700f
by bm0p700f
erm that sterotyping right there. Chinese rims can be made by reptuable manufacturers you have not heard of.
Yes aero depends mostly on the depth anyway. Also I am not a believer in conventional wind tunnel tests. Theres too many assumptions and the flow too static to draw any real world conclusions.
DT swiss do many funny things with there wheel design which are not optimial to hit weight goals. These are ignored because of the DT Swiss brand.
tw88
by tw88
Did you eventualy got the decals of the rim?
ilikegreen
by ilikegreen
Black permanent marker will stealth the decals up with minimal fuss. Plus you now have a subtle lettering effect which is pretty tidy.
dricked
by dricked
Have you ridden these much, how do you like them?
