Campagnolo brake shoes
markyboy
by markyboy
Campagnolo brakes shoes with the spring,changing out a set of pads imo is a pain in the arse.
Shimano unscrew slide out slide in so simple,why do campag complicate things?
Colnago master with campagnolo super record 12
Pinarello f8 with dura ace di2
Eddy merckx 69 ultegra disc winter bike ultegra r8000
skidrrr
by skidrrr
Also the way shima align brake caliper tention is more elegant to me
So ame question here. Why campy design is so complicated?
jekyll man
by jekyll man
The ones with the retaining springs are the easiest, esp in the winter when you're wearing blocks down fairly quickly.
Stick a jewellers screwdriver behind the tang, and lever out a little, then slide the insert out.
Simples.
The older push fit were worst, closely followed with the crappy chocolate headed screw idea that shimano use.
Official cafe stop tester
corky
by corky
Best are EE cycle works no springs no screws just a tab and they take more prevalent Shimano pads........there should be no other design.
markyboy
by markyboy
jekyll man wrote: ↑
Fri Dec 28, 2018 1:14 pm
Simples.
Those retaining springs are quite stiff and i find with a little screwdriver you mark the shoes when lifting it up.
jrobart
by jrobart
Unfortaunteky I broke the spring on the front right block about two months ago. Got the pad in, but it doesn't sit perfectly and now shutters when breaking! Fortunately, it happened just as I was changing to my winter/commuter/gravel bike so I've been able to ignore the issue for now. And of course, finding a campy SR skeleton block ain't cheap!
The Stable (I really need to update this) http://www.flickr.com/photos/121194764@N07/albums
622 SLX | Axiom SL | Mudhoney SL (retired) | S Works Crux | Fondriest Carbon Magister | Fat CAAD 1
jekyll man
by jekyll man
jrobart wrote: ↑
Fri Dec 28, 2018 8:39 pm
You can buy the springs separately, i got a pack from Graeme F-K on here, they weren't expensive.
FWIW i had 2 break on brand new unused brakes, and ran them for 12 months before i thought about replacing them; perhaps there was enough indent in them to stop pad movement.
Calnago
by Calnago
Ha... those things are such an annoyance. I actually removed them during my C60 build but later added them back. Since even though I could never imagine myself installing them backwards, it was remarkable easy for them to slide out if you just happened to be straddling your bike rocking back and forth talking to someone while holding the brakes or something fidgety like that. As pointed out by @SuperDomestique in that thread, a much better way to remove them is to just get a teensy screwdriver or something underneath the rear to pry them up a bit so that you can get a good grip on them with some needle nose pliers then just peel them away from the brake shoe without ever touching that spring. I was quite proud of myself for my intital idea to remove the springs completely, then realized how dumb I was after been shown a much easier way.
TonyM
by TonyM
This is the (Jagwire) tool that I use since I have these Campagnolo brakes...
So easy with it :thumbup: :thumbup:
https://jagwire.com/products/tools/pad-press-plus
https://www.youtube.com/watch?v=va4W_HmhxNA
markyboy
by markyboy
TonyM wrote: ↑
Sat Dec 29, 2018 5:43 am
Thats a handy little tool,but for me shimano pads slide in and out so easy i leave them attached to the bike.
What im saying with campag is that little spring is a pain to lift without marking your shoes,and also the pads are stiff to get out.
