Di2 users
markyboy
by markyboy
I am new to dura ace di2 and just finding my way around with the e tube etc,my question is that is it normal in manual mode that when in the small chainring
you cant change all the way down the cog to the smallest sprocket.
It wont let me it stops a couple short.
Colnago master with campagnolo super record 12
Pinarello f8 with dura ace di2
Eddy merckx 69 ultegra disc winter bike ultegra r8000
WILLIAMDENYS
by WILLIAMDENYS
Youre having the 9150 dura ace?
With the 9150 DA and 8050 ULT there is something on there where if youre in the inner chainring you cant ride in the last two cogs.
Verzonden vanaf mijn iPhone met Tapatalk
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
markyboy
by markyboy
Yes just installed 9150 and like i said it wont go into the last 2 cogs in the small ring.
WILLIAMDENYS
by WILLIAMDENYS
Yes i think its just normal , i have 8050 and i have the same like you. I actually like it because if you use the last two cogs the chain rubs against the outer chainring.
markyboy
by markyboy
Yes thats right i would not use those 2 gears anyway but just wondered.
All i have to do now is find my way around the app.
What i need to do is see if i can use the buttons on the top of the shifters if they exist.
WILLIAMDENYS
by WILLIAMDENYS
Yes if you plug in your bike you use the app with controls. Then you can choose between contoller X Y and the other one are the top buttons which you can setup to shift up down rear and front.
markyboy
by markyboy
Ok thanks,what i might do is see if i can toggle between screens on my wahoo with the top buttons hopefully, but just need to try and sort it out.
TheDoctor
by TheDoctor
markyboy wrote:
Wed Dec 19, 2018 9:58 pm
I'm controlling my Wahoo Elemnt Bolt with the top buttons, easy to set up. You do need a Shimano D-Fly unit (EW-WU111A) though, for the wireless communication between the Di2 system and the Wahoo.
Info on the set-up and functionality here:
https://wahoofitness.yonyx.com/y/conver ... 764e11d2f4
Scott Addict Premium Disc
Argon 18 Nitrogen
Specialized Tarmac SL4 Pro
Canyon Exceed CF SLX 8.0
ParisCarbon
by ParisCarbon
What are your front chainrings... My CX bike has Ultegra Di2 with a 46/36 setup.. If I remember correctly we went in the etube software and set the front rings to be 53/39 and not the 46/36 combo and it allows the bottom 2 cogs on the small ring...
beanbiken
by beanbiken
ParisCarbon wrote:
Thu Dec 20, 2018 2:15 am
What are your front chainrings... If I remember correctly we went in the etube software and set the front rings to be 53/39 and not the 46/36 combo and it allows the bottom 2 cogs on the small ring...
^^^^ yes this, in etube set front CRs to 53/39 if you want to use the last two sprockets with your small CR..... which technically is less than optimal anyway.
BB
BB
Coffee & carbon
arty118
by arty118
The new firmware will not allow the RD to shift to 2 lowest sprockets while you are in the small chainring if the chainring difference are greater than 14 (52/36 or 50/34) You can go around this by set your chainring as 53/39 in the e-tube app. I have 50/34 chainring with 53/39 setting in the e-tube app and I can shift to lowest sprocket without problems.
avispa
by avispa
markyboy wrote:
Wed Dec 19, 2018 9:34 pm
If you dissable syncho shift (by using full manual mode) and choose no-limit for the number or cogs you will switch while pressing the X or Y switches, then you are good to go. The latest firmware has nothing to do with this. In manual mode, the rider is in full control of the gears. I saw how most Team Sky bikes were set-up and they were all in manual mode; I guess racers at that level do not like surprises with the gears.
In my Di2 9150 and 8000 setups, I can just hold the switches and the chain will go up or down the cassette with no problem. One thing you have to be aware is that you must switch the front derailleur accordingly as it will not put your chain in the big or small rings, no matter what cog you are in the back.
I included a pic of my setup from the e-tube app for reference. Also, you can set the shifting to manual mode by pressing the buttons on your junction boxes from M, S1 and S2.
A solid light that stays on for 2 secs on the junction box will indicate you are in manual mode.
markyboy
by markyboy
TheDoctor wrote:
Wed Dec 19, 2018 10:30 pm
Ah great,i have the ew-wu111 which i thought was the right one.
markyboy
by markyboy
52/36 but i will look at changing it.
markyboy
by markyboy
Thanks guys great help,its all very tech for me but i am slowly getting there :D
