*Tour Aero Bike Tests*
The point of the saw tooth has always been to reduce steering moments and instability in dynamic conditions, allowing you to ride deeper wheels than otherwise possible in said conditions.
Tour magazine also inadvertently tested the old 404 against old 454, when they did the 2016 aeroad which came stock with 454, and released that result next to the same bike with 404 standard wheels being used as. control. They were close in that test, but 404 was slightly faster. I think a watt or two.
I would believe Hambini's chart over what the shill media spits out any day of the week. And Hambini isn't the only guy who feels the 454s are slow. So. Yeah. Everything I have seen plus the way they feel and they don't feel great, leads many to the conclusion that the 454s are slow. Why double down if they are a failure? There have been many cases where a company doubles down on a failing product, relentlessly trying to claw back lost R&D and production costs. It wouldn't be the first time and it wouldnt be the last.aeroisnteverything wrote: ↑Fri Jan 20, 2023 10:09 amHambini never tested anything at all, and you should forget you ever saw that chart. Zipp/SRAM, I am sure, did test their wheels, and if the sawtooth profile is a failure, they could easily have reversed themselves in the 2nd generation of it (i.e., just dropped it). I don't know whether it has a measurable benefit over a conventional wheel profile in terms of drag (rather than stability), but it sure is more difficult from a manufacturing standpoint, and if it performs worse, why make the effort?Nereth wrote: ↑Thu Jan 19, 2023 6:57 pm...Hambini tested last gens against last gens 404. The 404 tested in the top third of his lineup, around 55 to 65mm wheels. The 454 ranked in the bottom quarter, below the 303, around a lot of other 30 and 40mm wheels, bar some really poor performing flo 60s which got a specific call out for that.
Don't get me wrong, I am as cynical as the next guy about the bike/component manufacturers being serial bullsh1tters in terms what they claim vs reality, but in this particular case, I just fail to see a good reason for Zipp to knowingly go with a solution that is worse from aero perspective for their top of the line wheelset.
I don't own any zipp wheels, don't like Hambini videos, but it's totally believable to me that Zipp will continue to sell 454s even if it's 50% less aero than a conventional rim. Simply looking radically different and marketing it as being groundbreaking design in aero wheels will make it sell like hotcakes. They are in the biz to make money, not to provide the most aerodynamic equipment for the cycling world.
Sent from my Pixel 6 using Tapatalk
I see no reason the sawtooth profile would be faster if you compare it too the rim depth of the sawtooth’s highest point. A 353 should be compared to a 303 rather than a 404 for example. A full 60mm depth would always be faster than the sawtooth equivalence. Zipp wouldbt be seen claiming their 404 is faster than 454 for sure given the latter is more expensive.
This is the reason why Zipp - who a few years ago were huge fans of sharing wind tunnel tests comparing every wheelset and their mothers - stopped sharing data. Now it's all generic and subjective marketing talk.
Can you backup your claim? Hambini is not my favorite and I´m not going to blindly trust any of the online aero tests, but a claim that someone faked all his aero results and never tested anything requires some evidence.aeroisnteverything wrote: ↑Fri Jan 20, 2023 10:09 amHambini never tested anything at all, and you should forget you ever saw that chart.Nereth wrote: ↑Thu Jan 19, 2023 6:57 pm...Hambini tested last gens against last gens 404. The 404 tested in the top third of his lineup, around 55 to 65mm wheels. The 454 ranked in the bottom quarter, below the 303, around a lot of other 30 and 40mm wheels, bar some really poor performing flo 60s which got a specific call out for that.
tour mag test a bunch of 60mm wheels a year ago. dtswiss was fastest the zipp 454 were 1.5 watts slower.
Current Rides:
2023 Tarmac SL7 Di2 9270
ex 2019 S-works SL6
ex 2018 Trek Madone SLR Disc
ex 2016 Giant TCRAdvanced Sl
ex 2012 Trek Madone7
ex 2019 S-works SL6
Which seems about right when comparing a 62mm rim to a 53/58mm deep one.
The 454s aren't slow... they just aren't the best for outright straightline speed from an aerodynamic standpoint. That was never the claim either.
Has anyone actually had their hands on Simplon? I still haven’t seen one in the wild yet, but I am very curious about build quality and general impressions.
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
Burden of proof is on the other party. When asked, he never proved that he did. He shared a chart and had zero evidence (corroboration, pictures, source data, etc.) that the testing actually happened. None.Roadrocket wrote: ↑Sat Jan 21, 2023 8:11 pmCan you backup your claim? Hambini is not my favorite and I´m not going to blindly trust any of the online aero tests, but a claim that someone faked all his aero results and never tested anything requires some evidence.aeroisnteverything wrote: ↑Fri Jan 20, 2023 10:09 amHambini never tested anything at all, and you should forget you ever saw that chart.Nereth wrote: ↑Thu Jan 19, 2023 6:57 pm...Hambini tested last gens against last gens 404. The 404 tested in the top third of his lineup, around 55 to 65mm wheels. The 454 ranked in the bottom quarter, below the 303, around a lot of other 30 and 40mm wheels, bar some really poor performing flo 60s which got a specific call out for that.
There were oddities around his results. Some at odds with other tests. It foesnt help that he "tested" so many wheels, given the amount of resources that would take.
When people asked for any proof that the tests actually happened, he just said "It's top secret. The tests are real. Trust me."
So there are many reasons to be skeptical, and none that should make you believe the tests actually happened.
It doesn't look like Boeing or Airbus freely post their photographs on the internet other than library shots.
CarlosTheJackal wrote: ↑Mon Jan 23, 2023 7:18 pmIt doesn't look like Boeing or Airbus freely post their photographs on the internet other than library shots.
He doesn’t even have photos of the wheels he supposedly tested, but he does share complete videos on Chinese-brand wheels he receives for free. You’d think such comprehensive testing would come with other analyses, observations on the finish, stiffness testing, trueness/roundness, hub design, etc.
In the market for an all-out aero race bike this year.
Scott Foil RC Pro looks tasty, and light enough in a decent spec not to frustrate me in the occasional mountains.
Any thoughts on that vs competitors? Open to suggestions
Wonder how the new Foil and Madone will score in Tour test.
Thanks!
Thanks!
