FlatlandClimber wrote: ↑Sun Nov 14, 2021 4:06 pm
AJS914 wrote: ↑Sun Nov 14, 2021 3:35 pm
A friend has the Specialissima and it's gorgeous.
How do you translate the watts in the charts. Is it as simple as it takes 26 more watts to pedal the Specialissima over the Dogma at a certain speed?
The speed is 45kph. And this is only aero, not rolling resistance or chain friction or anything.
Regarding stack. Sometimes the bikes need mandatory spacers that's are not in the stack, sometimes it is part of stack.
Also, some bikes are tested with more spacers, wider bars or wrapped tops vs non wrapped tops.
There are a few things to consider that make these 20W difference, that are not "better frame".
It doesn't really matter if the frame by itself is faster, most bikes these days are designed with a specific handle bar in mind. If a frame was specifically designed and stated to work best with a certain wheel set, then there could be reason to use a different wheel meet for that bike. Seeing as that isn't the case the wheels should be standardized.
Additionally if the bike has fully internal routing, cables should not be mounted, but should be included in bikes without fully integrated cabling. Regarding bar tape, a standard bar tape should be choosen and be wrapped to just past the hoods or to the transition point on the bars if they have a step for bar tape. The lowest stack height that all the bikes can hit should be chosen. I also feel that two bottles with a standardized cage and bottle should be used as most people ride with two bottles. A the same drive train and tires should also be installed with an appropriate tire width based on whatever the standard wheel set is.
Either way the next tour aero bike test should be interesting. We might have a new madone, venge, s5 out by then along either the new ribble bike, the simplson, the felt ar, the orca aero
