I agree about the bars.Lina wrote: ↑Thu Jan 27, 2022 12:15 pmYeah, one should look at aero testing at most as a guideline. And the rider is still the biggest cause of drag on a bike. So getting into an aero position is more important than the frame aero as long as the frames are in the same ballpark. In a hypothetical case where you had an extremely aero frame that's 10 watts more aero than anything else in testing but it's impossible to have below 40 cm bars on it and you can't get as low as you'd want to on it and it's still a lot slower than some other frame where you can get into an aero position.
I don't know if I agree on the second point though. Is there really a race bike which one can not get in a low enough position? Maybe it's just me, but I have never encountered this problem when looking to buy a bike. Or maybe I just don't ride with a big enough drop.
You can get a size smaller otherwise to get lower stack.
I would also argue that you don't need a huge drop to ride in an optimal aero position, which is with your forearms parallel to the ground.
