Need help with Campy shifter install
Noctiluxx
by Noctiluxx
I'm transitioning from Shimano Di2 to Campy SR 12-spd mechanical on my 2018 De Rosa SK Pininfarina. The issue is with shifter cables. My mechanical told me he needs a cable guide specific to this bike. I bought this frame brand new but never received a cable guide of any type. Full disclosure, my mechanic is brilliant, easily the best in town, though he works primarily on Shimano and Sram 99% of the time. He told me and I know this myself, the internal carbon on this frame is extremely sloppy and would making shifting rough unless I had the cable guide made specifically made for this frame. I'm hoping there is simple solution otherwise I'll take my bike to a Campy specialist Bike Effect in Santa Monica to complete the build.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Giant Revolt Advanced 0
Calnago
by Calnago
Is that a “legit” De Rosa? If so, call or email them and ask what is up with the mechanical routing option. I suspect there must have been some sort of guide with the frame initially but since it was a Di2 install it got lost in the shuffle. Or, I wonder if they intended there to be a full length run of derailleur housing from through the top tube all the way though to the derailleurs. Would be weird, and there would have to be a stop somewhere along the way for the front derailleur. Sure you don’t want to stick with electric in that frame?... as any time I see mechanical cable routing through the top of the top tube like that, it screams bad bends and compromised shifting. I really have to wonder about design choices manufacturers make sometimes. In any case, it’s not a Campy issue, it’s a frame design issue. You’d have the same dilemma with Shimano 9100.
Miller
by Miller
Looks to me like full length housing is required. There should/could be a cable stop for the front mech at the back of the BB shell, accessible through the hatch.
Zakalwe
by Zakalwe
Definitely stick to electronic because that routing for mechanical is seriously messed up. It’s almost as if Pininfarina aren’t actually bicycle designers
robertbb
by robertbb
I just want measurements/pics of your 25mm contis on the bora ultra... :lol:
Noctiluxx
by Noctiluxx
Zakalwe wrote:
Mon Dec 17, 2018 9:19 pm
Neither is De Rosa!
Noctiluxx
by Noctiluxx
robertbb wrote:
Mon Dec 17, 2018 9:21 pm
Measurements?
robertbb
by robertbb
Noctiluxx wrote:
Mon Dec 17, 2018 9:54 pm
Measurements?
Yep, measurements... as in, how wide do they measure at 100PSI? they look a fair bit wider than the rim width
(Thanks for the pic... great looking rig!)
Noctiluxx
by Noctiluxx
robertbb wrote:
Mon Dec 17, 2018 11:31 pm
Measurements?
Don’t have a digital caliper, but based on a conventional tape measure, the tires are a tick under 1” at 100 psi. I have the two pairs of Bora Ultras wheelset, both with Conti GP 4000 SII’s, and hands down the best wheels I’ve ever owned.
AJS914
by AJS914
They should be 27mm. I just fit the same tires to my C59 on 25mm wide (18mm internal) rims. The biggest problem with GP4000s is that they are tall.
https://www.bicyclerollingresistance.co ... i-23-25-28
robertbb
by robertbb
Noctiluxx wrote:
Tue Dec 18, 2018 2:18 am
Measurements?
Cheers for that! Yep, I also have two sets of Bora Ultra 35's; tubular (had for a few years, used sparingly for alpine climbing) and now I just picked up some clinchers to use regularly. Best wheelset money can buy!
Sorry to derail the thread :)
wilwil
by wilwil
Its sold as electronic or cable. My guess is that BB plate is replaced with one with indents and cable entry and exit holes. Bike shops are really good at losing the small parts that come with frames.
