How to remove carbon stem cap
seanhunt1981
by seanhunt1981
Hi Guys, first time poster long time listener etc... apologies if this may seem like a silly question but i'm totally stumped by this, I went to install a new stem today but how do I get the stem cap off this first? I was hoping it would twist or screw off revealing the bolt underneath but no such luck. I'm reluctant to force it off with some leverage as it might snap. I'm a little confused. Anyone any ideas?
Calnago
by Calnago
Loosen the stem bolts and it should slide right out, as that squeezing force is the only thing holding it in place. The preload etc is all done in the headset itself.
seanhunt1981
by seanhunt1981
Sorted. Thank you very much!
bikeboy1tr
by bikeboy1tr
Seems like a strange thing but when I pull mine out sometimes it has a vacuum effect happening. You end up double checking the stem clamp bolts again and yes they are loose, just have to pull little harder and it goes pop.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
wheelsONfire
by wheelsONfire
Oh, Jesus Christ,... how high is the spacer stack??
40mm or?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
