BMC SLR01/ENVE 4.5ar ses????
WESTMOTORSPORTS
by WESTMOTORSPORTS
I am interested in finding out if my enve 4.5ar wheels with 700x28 tires will fit on a 2019 BMC slr01 disc frame.
LawSchwein
by LawSchwein
I believe this is the exact combo that my buddy in SoCal uses. Take that as a tenative "yes." I will email him to make sure that's right.
Mainstay Bike - Pinarello Dogma F10 - Campagnolo Record EPS, Campagnolo Bora Ultra 50
Climbing Bike - Cervelo R5 - Campagnolo Super Record Mechanical, Enve 3.4
spdntrxi
by spdntrxi
Mine have Pro-Ones @ 28c... now that I have a few hundred miles on them, I measured them again.. from 31.7-.8 to 32mm @ 60psi. so you are probably going to want 2.5-3mm min on each side.. 4 even safer.
superyeho
by superyeho
Team dimension data are apparently using the AR model on the cobbled classics.
Just saw a GCN video of one of the rider's bike.
Sent a question to enve but did not get a reply yet
Im on the same boat...SLR01 disc
itsacarr
by itsacarr
I have seen this combo but hopefully this helps clarify:
https://www.instagram.com/p/Btco2XOla0h/
Several photos to help your decision.
I believe they have a couple similar builds on the page as well.
spdntrxi
by spdntrxi
WESTMOTORSPORTS wrote:
Mon Dec 03, 2018 10:01 pm
it should... I have a TimeMachine Road 01 (the new one) and they fit... I'm sure the SLR01 has more clearance.
bilwit
by bilwit
itsacarr wrote:
Fri Apr 12, 2019 4:13 pm
That's a roadmachine which is spec'd to "30mm" but you can actually put a 30mm rim on it so I suspect realistically the tolerance is more like 32mm. The Teammachine is spec'd for 28mm.. I suspect it could clear the new ARs but the tire would have to not balloon much beyond the rim if it's a clincher
spdntrxi
by spdntrxi
TimeMachine Road is also spec'd for 28... and they fit with some space to go. They are pro-ones.. so they are over 30mm in real life
willmac
by willmac
I’m getting my teammachine at the end of the month and a buddy of mine has some 4.5AR’s. I’ll see if I can’t do a test fit with his rear wheel for you.
willmac
by willmac
Funny enough, this just popped up on Instagram. Pretty sure they are 4.5AR’s
https://www.instagram.com/p/BwKLWzaADvs ... dm712ssa7d
superyeho
by superyeho
Any news on the 4.5ar fitting thr slr01?
moyboy
by moyboy
Heard they mught rub. One guy at my lbs had ar and switched to zipps due to rubbing. Not sure what tires they were using.
MarkNiko99
by MarkNiko99
Hi Guys,
Just wondering if someone can confirm if the Enve 4.5 AR with 28mm will have enough clearance?
Anyone running same setup now?
Thanks.
