Ultrasonic cleaners, how good do they clean chain internals?
C36
by C36
Reading the some older Friction-facts reports about the difficulty to properly clean a chain I thought about the ultrasonic cleaners.
While a brush and diesel (or other cleaner) do the job for a cassette, getting a chain cleaned between the pins and rollers require to do several bath with clean solvent.
Image(from zerofriction report)
Can ultrasonic cleaners work ? Yes... just tested one we have at work and brillant, impossible to find a single trace of contamination... but that’s a machine I can’t afford to have in my garage (10k€ machine with filtration and 5kw of Ultrasonic power...).
Who uses something like this and does it really work well?
alcatraz
by alcatraz
I have a small cleaner 50w 1.2L and I don't recommend it.
A problem I have is that when the water gets even luke warm the power starts to dissipate away. It simply can't handle heat and clean at the same time.
The piezo element inside is of the industrial looking kind, so that is maybe not the best way to recognize a good unit.
Anyway, if you plan to clean at high temperatures get ready to pay a lot of $$$. That's the feeling I have.
dgasmd
by dgasmd
For the love of whatever is sacred to you, just buy a damn new chain!!!!
TobinHatesYou
by TobinHatesYou
alcatraz, I find the heating unnecessary. What I do is place the chain in a ziploc bag and some slightly dilute degreaser and fill the rest of the ultrasonic cleaner with water. This keeps the ultrasonic cleaner from getting dirty and also allows me to use a higher concentration of degreaser.
Just make sure you’re using the right degreaser. Simple Green can harm a chain for example (even the Aircraft / Precision parts version.) I use Zep Citrus.
MikeD
by MikeD
TobinHatesYou wrote:alcatraz, I find the heating unnecessary. What I do is place the chain in a ziploc bag and some slightly dilute degreaser and fill the rest of the ultrasonic cleaner with water. This keeps the ultrasonic cleaner from getting dirty and also allows me to use a higher concentration of degreaser.
How is an acidic degreaser any better?
TobinHatesYou
by TobinHatesYou
MikeD wrote:
Mon Dec 03, 2018 4:38 am
Citrus degreaser is actually a medium-strong base. The degreasing agent is citrus oil, not citric acid.
Gearjunkie
by Gearjunkie
Do you need to clean the citrus oil degreaser off the chain before re-lubing?
alcatraz
by alcatraz
Thanks for the tip. I'll try to clean in room temperature water and see.
The bowl is already tiny so cleaning is a breeze. If I get a larger cleaner to fit mtb cassettes, derailleurs, chainrings, then I'll try the bag trick.
I'm treating my chains in hot paraffin wax so I'm not sure how well it will work with unheated water. Worth a try.
TobinHatesYou
by TobinHatesYou
Gearjunkie wrote:
Mon Dec 03, 2018 5:10 am
Always flush out whatever cleaning agent you use with water because any leftover is 1) still caustic and 2) going work against your lube. Thoroughly dry with clean shop rags and/or an air compressor.
alcatraz wrote:
Mon Dec 03, 2018 5:12 am
If you're dipping your chain in wax you don't need to degrease your chain after the first time you strip the factor grease off. Simply immersing the chain in hot wax and agitating the chain will clean your chain (and make the pot of wax a little bit dirtier.) I created mesh bottom for crockpot so debris/grit can settle at the bottom.
NickJHP
by NickJHP
I don't think ultrasonic cleaning is worth the trouble of having to remove the chain for cleaning. I just run the chain through the Park chain cleaner with solvent (white spirit or petrol) once a week or after I've ridden in the rain, wipe off the excess solvent, and then re-lube. I get at least 15000-20000km out of a chain before it has 0.5% wear and needs replacing - ie 24 links measuring 12-1/16".
TobinHatesYou
by TobinHatesYou
NickJHP wrote:
Mon Dec 03, 2018 6:45 am
For new chains my process is:
1) Old water bottle filled with OMS (never gets changed out, just topped off and occasionally decanted. Drop new chain in bottle and shake it a few times. Leave to settle for 10-15min.
2) Extract chain, wash off mineral spirits, place chain in ziploc bag with dilute citrus degreaser. Place bag in ultrasonic cleaner receptacle (filled with plain water.) Clean ultrasonically for about 10min.
3) Extract bag/chain, wash off degreaser. Wipe down and spray off remaining water with air compressor.
For cleaning chain lube off a used chain:
1) Fill chain cleaner with dilute citrus degreaser and backpedal chain through it.
2) Repeat at least once or until the solution stops turning very dark.
3) Repeat a few times except with plain water to flush remaining degreaser.
4) Wipe down with rags and spray off remaining water with air compressor.
It’s rare that I fully degrease a used chain...usually just when I want to switch lubes.
I prefer the degreaser to OMS or diesel/kerosene because it's not flammable and easier to dispose of.
alcatraz
by alcatraz
Aren't mineral spirits and petrol both mineral based? If you use a wax based chainlube won't the two repell eachother?
15-20k sounds amazing. You must be 50kg pedaling high cadence right?
Bondurant
by Bondurant
It is astonishing how much time people put into something as trivial as this.
eric01
by eric01
Slightly off topic... decades ago I used to put my chain in an old water bottle, pour some gasoline in there and shake it. Got my chain spotless. Now older and wiser I know how much of an environmental disaster this is...
