Road disc 160/160 vs 160/140mm in the mountains
mrlobber
by mrlobber
There are numerous threads on road discs vs rim around here (and maybe the question on rotor sizes is buried inside them as well), but let's put that all aside for now.
Due to potential 20-30g savings, I'd be interested to swap rear to 140mm for my "light" disc bike. I live in a flat area, so I'd even be able to run 140mm rotors on road disc all day long, however, given the occasional trips to Alps, I'd like to hear real experiences from people who run road discs in mountains daily or weekly - how much rear 140mm reduces actual braking performance and/or time to heating the brakes up.
My weight is in the 70...75kg territory.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
TobinHatesYou
by TobinHatesYou
If you care about the weight, go ahead. You should only be feathering/trailing the rear a slight bit during aggressive descending. I just think the asymmetry looks goofy so I haven't bothered going 140mm in the rear.
MarcFaFo
by MarcFaFo
It is very common to use 160/140 set-up. Also in the mountains I have seen last summer during the Marmotte
siim
by siim
I used 160/140 this year in Dolomites (Maratona) and it was absolutely fine. My weight is about the same as yours.
moyboy
by moyboy
I used 160 160 in the Dolomites (Maratona). I think 140 would work well too. you do not want to lock that rear!
I'm just a horrible descender!
Will be going to a 140 rear this year.
siim wrote:
Fri Nov 23, 2018 1:13 pm
tnkn
by tnkn
I've used 160/140 in the mountains. Was absolutely fine at 68kg.
Not once did I think I needed more stopping power.
MichaelB
by MichaelB
I use 160/140 on hills with no issue and I’m 95kg.
Mind you, run Zee calipers so a much bigger pad than the flat mount ones
Edit - damned phone auto correct!!
rainerhq
by rainerhq
What about 140/140 for 67kg rider in the mountains?
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
mattr
by mattr
Think you'll be into "how good is your technique" there.........
I switched from 180/160 to 160/140 on my XC bike, and while i didn't actually have any problems (the brakes still worked) i did manage to slightly over heat/heat treat the front disc, as far as i can tell, it's hit about 300-350 degrees in a few spots. Difficult to tell exactly due to the fact that it's a friction surface, but the arms were discoloured where they meet the friction surface.
The 180/160 combo i had on that bike prior to that have been on for several years with no issues (and no colouring of the disc at all.)
Best i've seen was a 200mm disc from a tandem that had overheated so badly it had permanantly distorted by about 10mm and was dark blue..........
nulldreiundreissig
by nulldreiundreissig
rainerhq wrote:
Mon Nov 26, 2018 6:33 am
Sitting at 62kg and living in the Zurich-area with regular trips to alpine passes, I was torn between 140-140 and 160-140, too.
Went for 160-140 ultimately, because it’s only a few grams saved and I felt more comfortable with the option to choose 140s in a second stage.
I’d rather consider latex inner tubes on a disc equipped bike for some easy weight savings than probably sacrificing some breaking power.
spdntrxi
by spdntrxi
Allroad 160/160
TriBike 160/140
Road 160/140
83kg.. no lack of power with the 140
