S-works Tarmac SL5 project seems heavy
benjieb
by benjieb
Thanks for all th input. Spec and plans have changed a bit. I've decided the go for an SL6 rather then the SL5. 200g saving, but in reality it's because the SL6 has less headaches with things liks SCS chainstay silliness, post mount calipers and quick release skewers that the SL5 comes with.
Final build is below and comes in at 6.99kg. Most of the parts have arrived and been weighed (says actual after it). I'm a bit disappointed with the weight of the rotor aldhu crankset though. I've seen people on this forum report weights of 564g for a 39/53 with 172.5mm cranks, but mine is coming out at 624 for a 36/52 on 170mm cranks.
S-works Seatpost 176
S-works Tarmac SL6 Frame 800
S-works Tarmac SL6 Fork 387
headset 101
S-works SL 100mm Stem 123 actual
S-Works Shallow Bend Carbon 40cm Handlebar 180
Hunt aero 30 wheelset 1379
Rotor Aldhu 52/36 170mm crankset 624 actual
Dura ace 9100 11-28 Cassette 193 actual
Dura ace 9100 Chain 255 actual
2 x Hutchinson fusion 5 Galactic 25mm tubeless tyres 415 actual
Tubeless valves 20
Tubeless sealant 60
Supacaz super sticky Kush bar tape 96 actual
Selle SMP composit carbon 174 actual
2 x Bontrager XXX bottle cages 30 actual
Dura ace 9170 di2 shifters 346 actual
Di2 battery 51 actual
Dura ace 9170 caliper - rear + hose 200
Dura ace 9170 caliper - front + hose 158 actual
Ultegra 8070 rear mech 238 actual
Ultegra 8070 front mech 129 actual
2 x Dura Ace Ice Tech Freeza Centre-Lock Rotors 218 actual
Dura Ace 9100 pedals 228 actual
di2 parts - juntions boxes wires etc 300
Rotor crankset spacers 43 actual
Thru axles 12x100 and 12x142 75
Basher74
by Basher74
Sounds awesome, would love some pics!
Defo get it down further with different seat, DA mechs and S-Works chainset. Decent weight for a disc road bike though, enjoy!
scale29
by scale29
doubt that Hunt wheelset will weight what they say it does either, normally quite a bit over from what I was reading, that's why I went with CLX32.
Basher74
by Basher74
scale29 wrote: ↑
Thu Dec 13, 2018 8:42 pm
Roval CLX wheelsets are ma hoo sive lee under rated. One of if not thee best wheels ever made.
Basher74
by Basher74
Basher74 wrote: ↑
Thu Dec 13, 2018 9:25 pm
scale29 wrote: ↑
benjieb
by benjieb
The CLX32 wheelset in Aus is $3600, the hunt wheelset is $1600. Roval wheels may be underrated, but the price certainly isnt.
jaketim114
by jaketim114
Definitely show some pics. I'm thinking of doing a build like this.
benjieb
by benjieb
Finished build came in at 6.77kg on my mechanic’s scales. I weighed it on mine after adding cages and Garmin mount and got 7.01kg. I guess the real weight is somewhere between the two.
https://www.instagram.com/p/BszOicuFvOu ... n2p0trpmg9
