Post your Small budget weight saves
RocketRacing
by RocketRacing
I got eebrakes in very good condition used for maybe 1/3rd the cost of new. Still not cheap... but i saved a lot of money for callipers with near dura ace braking, and 171g without pads for the pair.
maxxevv
by maxxevv
Lewn777 wrote:
Sun Nov 18, 2018 4:30 am
  • Titanium cleat bolts 30-50g?
  • Changing stem bolts to titanium and various brake bolts 20g-40g
These are highly optimistic figures. You'll be hard pressed to touch 25g of weight saving for the cleat bolts.
Likewise for the various screws, brake and pivot bolts. And to clarify, these specialised bolts are not " cheap" per se either.
  • Lighter pump, up to 50g
That's pretty conservative. Cheap pumps and the really light ones can be as much as 200g difference.
Then again, the really light ones are not exactly "cheap" either.
Stendhal
by Stendhal
My suggestion -- and I am surprised no one has mentioned it yet -- is to fill your tires with helium instead of air. Helium is lighter than air so you'll save some grams. Plus, you may be able to float up the climbs, ahead of your club ride friends. (Why else do you think Ridley named its climbing bike the Helium)? Also, at coffee stops, you can delight your friends by taking a nip from the tire valve and speaking in a squeaky voice.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
WILLIAMDENYS
by WILLIAMDENYS
RocketRacing wrote:I got eebrakes in very good condition used for maybe 1/3rd the cost of new. Still not cheap... but i saved a lot of money for callipers with near dura ace braking, and 171g without pads for the pair.
If i would see a good price for the ee brakes i would sure buy them... the lowest price i did see was 475 euro used brakes.
Verzonden vanaf mijn iPhone met Tapatalk
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
maxxevv
by maxxevv
Stendhal wrote:
Tue Nov 20, 2018 3:49 am
My suggestion -- and I am surprised no one has mentioned it yet, to my knowledge -- is to fill your tires with helium instead of air. Helium is lighter than air so you'll save some grams. Plus, you may be able to float up the climbs, ahead of your club ride friends. (Why else do you think Ridley named its climbing bike the Helium)? Also, at coffee stops, you can delight your friends by taking a nip from the tire valve and speaking in a squeaky voice.
Except that you can't use helium on normal rubber tubes nor tyres ....
cro2
by cro2
I'd take the helium idea with a grain of salt Image
Wysłane z mojego LG-K430 przy użyciu Tapatalka
C36
by C36
Not sure we have to mix “big gains” and “cheap gains”. EeBrake saves a lot but the $/g is not great (150g for 450$ that’s 0.3g/$)
2lo8 who did an interesting zero carbon bike has a website where he listed really interesting savings where 2g/$ is just “OK” and 5 or 6g/$ very good.
https://2lo8.wordpress.com/parts-listing/
shimmeD
by shimmeD
I don't run cable adjusters on my bikes, external or internal routings. Just chuck your cable adjusters into your spares box, free grammes saved. Only applicable to mechanical though.
Less is more.
Lewn777
by Lewn777
maxxevv wrote:
Tue Nov 20, 2018 3:46 am
OK some of those postings were guesses, but you also seem way off.
The titanium cleat bolts include the shims for Shimano systems, so the weight is pretty much right.
I live in China and good (and garbage) quality titanium and aluminium alloy bolts are fairly cheap per gram.
Also the pump figure is about right. I own several mini pumps and I actually use my heaviest at 103g, becuase I find it the most use-able, so I have no clue what you are talking about there. Maybe it's easy to find a 200g difference between floor pumps, but not mini pumps.
I suggest that you might like contribute to the thread by posting your own ideas or something someone else has found about cheap ways of taking weight off their bike. Or if you really want to find someone else wrong than actually try using data rather than guesses. We're mostly all here to learn.:thumbup:
claus
by claus
WILLIAMDENYS wrote:
Mon Nov 19, 2018 7:53 pm
Im thinking about buying a smud full carbon saddle... saves around 150grams of my prologo zero 2 pas... someone has experience?
Works fine for me.
But obviously saddles are a very personal choice.
WILLIAMDENYS
by WILLIAMDENYS
Works fine for me.
Strong enough?
northwestern
by northwestern
Haircut, saved 20 grams with $20.
claus
by claus
WILLIAMDENYS wrote:
Wed Nov 21, 2018 2:26 pm
Strong enough?
For me: yes (but I weigh less than 60kg)
r3m
by r3m
Expandeur !
Stock expandeur are heavy....
WILLIAMDENYS
by WILLIAMDENYS
claus wrote:
Strong enough?
I’m 60 so guess it will be good for mee too
