Post your Small budget weight saves
WILLIAMDENYS
by WILLIAMDENYS
Just exchanged my supacaz barends for lizard skins barends... saved 25 grams for some bucksImageImage
Verzonden vanaf mijn iPhone met Tapatalk
- ridley fenix sl 105 - not lightweight
- sworks tarmac sl 5 r8050 di2 - vision tc 24 wheels = 7,1kg
C36
by C36
Remaining on the bar.... bar tape. They use to come with a lot of overlap, with a tight wrap and minimum overlap I recall gaining 18g (48 to 30)
After
Left overs
hambini
by hambini
went to the toilet, saved 468g
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
RocketRacing
by RocketRacing
Hahaha... poop.
Where do you find 32g barends?
There needs to be a “heavyweight build”. Select the heaviest components... i bet you could do it cheap
ubers
by ubers
hambini wrote:
Fri Nov 16, 2018 11:25 pm
did you eat again though? if so, total waste :D
RocketRacing
by RocketRacing
But in seriousness:
- unwrap tops
- lightweight elite bottles
- berk saddle was good money vs grams saved
- used frame with used r-sys slr wheels was not “cheap”, but saved a mint over buying new.
- wren stem
- mt zoom axles
WILLIAMDENYS
by WILLIAMDENYS
RocketRacing wrote:
Sat Nov 17, 2018 12:16 am
Hahaha... poop.
these barends are the supacaz screwable plugs that came original
Lewn777
by Lewn777
  • lighter tubes and spare tubes up to 100g a pair
  • lighter tires - up to 100g a tire
  • carbon soled shoes vs cheaper shoes 300-400g
  • lighter clothing, depends on weather but on average 200g-300g
  • Paired down multitool (up to 100g)
  • Bringing your front door key but not your entire bunch of keys - 100g or so
  • lighter helmet 50-100g
  • Squewers save usually 50g-70g or so a pair
  • Alloy cable outers - approx 40-50g
  • Titanium cleat bolts 30-50g?
  • Lighter phone (usually around 50g)
  • Steerer expander saves up to 50g (not always recommended)
  • Lighter pump, up to 50g
  • Garmin rubber band mount - saves 20-50g depending on what you are replacing it with
  • Changing stem bolts to titanium and various brake bolts 20g-40g
  • Titanium cassette lock ring saves up to 10g depends on make/model of cassette
  • Top cap with titanium or alloy bolt up to 5g or so
  • No speed sensor 15g
  • Stem spacer rings from alloy to carbon fiber 2g or so a ring
WILLIAMDENYS
by WILLIAMDENYS
I’m thinking about buying a smud full carbon saddle... saves around 150grams of my prologo zero 2 pas... someone has experience?
reedplayer
by reedplayer
brakes 50.- euro (new), slightly tuned
stem 39,90 euro (new), painted and slightly tuned, got it down to 111 gr by using a different plate lying arround.
WILLIAMDENYS
by WILLIAMDENYS
reedplayer wrote:brakes 50.- euro (new), slightly tuned
What brakes are these? How are these working?
reedplayer
by reedplayer
those are sram rival brakes, old model. they are working fine, although in mountain area.
WILLIAMDENYS
by WILLIAMDENYS
reedplayer wrote:those are sram rival brakes, old model. they are working fine, although in mountain area.
Oooh and these are pretty light i see
RocketRacing
by RocketRacing
Another cheap option is to find a scale that measures too light.
But in all seriousness, cheap and light rarely go together.
But i do have a 21g hand pump. Good luck getting anything over 40 psi though...
reedplayer
by reedplayer
WILLIAMDENYS wrote:
Mon Nov 19, 2018 9:52 pm
the old model. the current ones are about 310 gr.!
