What Ax-Lightness stem I choose? Rigid or Rigid with two clamps
mendiz
by mendiz
Hello, I have seen Ax Lightness has the model Rigid with two different system of clamps. Anyone has experince with both? what would be better clamping the handlebar?
You don´t stop riding when you get old, you get old when you stop riding.
imunwired
by imunwired
I feel like I would make that decision not based on what would clamp better (as I am sure they both do fine), but based on what kind of computer you use, if any, and what kind of computer mount you’d like.
For me, the availability of out-front mounts vs side-mount options depending on what bar you are paring with this may sway your choice.
ome rodriguez
by ome rodriguez
The rigid with two clamps is the newer version which I got recently.
mendiz
by mendiz
I am not going to use mount for Garmin, thanks to ome.
shillc
by shillc
Anyone have an up front computer mount recommendation with the dual clamp system?
I have not found anything that comes with M4 screws in that width.
