New Continental 5000S Tires - Tubeless Compatible
zefs
by zefs
They probably stretch to a point and not permantly, because of initial inflation. Also it's probably the casing itself that stretches and not the beads which are also reinforced in tubeless tires.
andreas
by andreas
These went on effortlessly on my Roval CL50 rims, 25mm front 28mm rear. Rim spec 20.7mm internal, 29.4mm external. Only had to use my hands, no levers, soap or sealant. Easiest tubeless installation I've ever had!
commendatore
by commendatore
Recently mounted a set to Bora WTO. No tools needed? Not a chance. I'm not sure I would have gotten them on without a koolstop bead jack, but someone with a bit more hand strength might have had better luck.
I find this a little reassuring, and have no fears about them coming off the rim during a flat. In light of the effort required I've abandoned any hope of carrying a spare tube. If orange seal or a dynaplug won't fix it a taxi will have to get me home. :shock:
kevinw
by kevinw
commendatore wrote:
Wed Jun 12, 2019 8:42 pm
Recently mounted a set to Bora WTO....
What size tyres? Sounds like a similar situation I had mounting a set of 25s to my WTOs. They did seem easier after they were warmer though. I used the levers that came with the wheels.
Tempted to drop down to 23mm tyres but assume they will be an even harder fit?
trex021
by trex021
I'm using the 25mm 5000 TLs on Astral Radiant rims. The rims have a 19.5mm internal width and the tires measure 27.5mm wide inflated to 90psi. So far they are great but I have to echo that they were the hardest ever tire to mount. I know what I'm doing with using the the full depth of the channel in the rim and mounting the valve area last. It was brutal but not impossible with good levers.
spdntrxi
by spdntrxi
just mounted some 28mm 5000TLs on Roval CLX50... OMG.. so easy.. easist time I've ever had with tubeless.
spud
by spud
mounted 28s and 25s to Light Bike 30mm wide rims. 28s went on with some heavy hand rolling. One 25 required use of a lever the same way a car tire is mounted (not as a lever, but as a pusher). Last 25 was a bear to get on, required heavy persuasion with lever. That said, I did this in my cold basement, the tires never got warmed up prior to mounting. 28s seated with a 140psi shot from my accumulator. 25s required 160 psi shot from accumulator to seat, all with valve core removed.
dtwolfen
by dtwolfen
Just got my 28mm and they weigh 337 grams. Hope they last a long time. Going to be mounted on 19mm internal rim. Got them for the comfort factor more than weight.
Sent from my LG-H700 using Tapatalk
Sock3t
by Sock3t
I ripped a sidewall on my 25's.
Giant piece of glass. I swerved to miss it with the front, it slashed the back.
60km's on that tyre. Done. Wouldn't have mattered tubless or tubed - had to get a ride home.
Boooooo
by Boooooo
How you can say was exactly a slash from a piece of glass? Personally noticed weakness in sidewall area (whatever brand of tubeless tyres); also other guys noticed sidewall rip increased rate when using wide rims (whatever tubless or tubed) . Would be relieved if you say was a piece of glas this time for sure
dim
by dim
Boooooo wrote:
Sat Jun 15, 2019 7:00 pm
you got a link to that?
Trek Emonda SL6
Miyata One Thousand
spdntrxi
by spdntrxi
because he said so ?.... not like he binned it and does not remember wha' happened.
Boooooo
by Boooooo
spdntrxi wrote:
Sat Jun 15, 2019 7:40 pm
asked only for a confirmation if was "presuming" or he was sure because is not always clear
Tried 2 brand of tubeless road tyres
-Mavic Yksion PRO UST after 1000 miles appeared an exterior crack identical shape in both front and read sidewall (by the way binned because of many cuts not because of sidewall failure)
-Vredestein Fortezza TLR almost brand new developed a sidewal rip (irrecoverable failure) in rear wheel while I was in a completely flat and smooth tarmac (ok I was in terrible roads till 10 miles before)
(if wondering about my weight: 72 kg)
I am evaluating to go back to clincher and tube on the rear wheel only
dim wrote:
Sat Jun 15, 2019 7:19 pm
viewtopic.php?t=152046
commendatore
by commendatore
25mm. They perfectly match the width of the wheels. I suspect a 23mm might eek out a marginal aero advantage, at least on the front.
spdntrxi
by spdntrxi
my 28mm measure 29.3mm on Roval CLX50.. so far so good.. feel pretty fast, still have not railed too many corners but I think my schwalbe pro-ones have a little more grip.. but we'll see as I wear them a little more.
Roval says the internal is 20.7 and 29.4 external.. so pretty good match.
