That was exactly my experience. While I was able to lever them on in comfort of my garage with no sealant to contend if I needed to get to put a tube in on the side of the road - getting one bead removed, adding a tube and reinstalling with sealant everywhere - forget about it.carbonazza wrote: ↑Sat Apr 10, 2021 6:43 amNot sure, I've put a new pair on Light bicycle rims yesterday. And they were impossible to put on without the dedicated pliers.
These are the only tires I can't put by hand.
Or maybe I got an old batch.
New Continental 5000S Tires - Tubeless Compatible
Forum rules
The rare times someone had a flat, the sealant or a dynaplug couldn't plug, it wasn't that hard to put a tube.tleo wrote: ↑Sat Apr 10, 2021 4:19 pmThat was exactly my experience. While I was able to lever them on in comfort of my garage with no sealant to contend if I needed to get to put a tube in on the side of the road - getting one bead removed, adding a tube and reinstalling with sealant everywhere - forget about it.
The GP5000 seems to give a little after some weeks/months, and is easier to remove and put back.
- seamaster76
- Contact:
My GP5000 with 1.000km
Those loose strings are a pain. I've had them wrap around the derailleur pulley bearings and behind the freewheel. I had to remove the freewheel to remove them. One of the reasons I won't buy Continental tires anymore, once I've used up my inventory. When I see a string I cut it with a scissor now rather than ignore it.
Been using Conti's since GP3000 days.
The 4000 and on have had the strings.
Don't recall on 3k.
I just cut em off.
Never caused an issue.
Don't recall on 3k.
I just cut em off.
I recently mounted a set of GP5000 TL 700 X 28 tires onto some ICAN Aero 40 rims. The tires went on easily and held air with sealant. Total weight was 935 grams for the front wheel (tape, tires and sealant) and 1381 grams for the rear wheel (tape, tires, sealant and cassette). I have been running them at 70 psi front and 80 psi rear and am happy so far. They role fast and are very compliant.
Cinelli Superstar - Campagnolo H11
Tommasini Custom X-Fire gravel - EKAR
