New Continental 5000S Tires - Tubeless Compatible
Forum rules
Thanks for the tip. I don’t ride in the rain but if i do end up riding in the rain I will take it easy.
So far I’m amazed at how fast these tires are. I can tell by the higher terminal velocity on descents. And I’ve already gotten a few PRs on downhill Strava segments that I rode all the tim. If the poor wet grip is the only compromise I have absolutely no issue with it.
- Gearjunkie
Interesting.
What are you putting on for the winter jj911c2?
What is interesting is how many people use racing/low rolling resistance tires for winter/rainy rides then complain about grip.
I've also seen 1 star reviews for the same reasons. Atleast you did the right choice and removed the tire for something safer for winter use
Conti Gp4000s II have excellent cold& wet grip, and we don't have Californian winters here in Austria.
Did this really change for the 5k or is this tire myth?
I found the 5k to have significantly less wet grip than the GP4KSII.Marin wrote:Conti Gp4000s II have excellent cold& wet grip, and we don't have Californian winters here in Austria.
The best sealant is almost always going to be Orange Seal (regular.) It has the best combination of sealing ability and endurance/lifetime. Some "thicker" formulas like Stan's Race will plug large punctures, but at the expensive of endurance/lifetime and it tends to clog valve stems.
Thanks! Very kindTobinHatesYou wrote: ↑Tue Jan 22, 2019 4:15 amThe best sealant is almost always going to be Orange Seal (regular.) It has the best combination of sealing ability and endurance/lifetime. Some "thicker" formulas like Stan's Race will plug large punctures, but at the expensive of endurance/lifetime and it tends to clog valve stems.
How long do you reckon an application last on average for a climate like the UK? Not too hot not too cold. To be on the safe side. I guess reapplying involves cleaning the old one first?
If you don’t puncture, I’d expect 40mL to last ~6 months in a climate like the UK’s. That should be longer than the lifetime of a high-end tire.
I will just add sealant if I can't hear any sloshing around in the tire.
40mL of sealant weighs 40g initially, but only about 5g when completely dried out. It's not worth the effort.
Thanks a lot!TobinHatesYou wrote: ↑Tue Jan 22, 2019 7:54 am
Six months is optimistic, I'd put it at three months tops - I live in UK. I've taken to running tubeless on my commuter bike which, like many commuter bikes, sees little maintenance. Last month one tyre seemed to be losing pressure faster than expected. I checked and it was completely dry inside. That took less than six months.parajba wrote: ↑Tue Jan 22, 2019 1:35 pmThanks a lot!TobinHatesYou wrote: ↑Tue Jan 22, 2019 7:54 amIf you don’t puncture, I’d expect 40mL to last ~6 months in a climate like the UK’s. That should be longer than the lifetime of a high-end tire.
Bear in mind that if the sealant does its job and seals a flat, you'll lose some sealant volume in that process.
6 months is longer than the lifetime of a high-end road tyre? Not in my shed!
cycling / nature / music
