New Continental 5000S Tires - Tubeless Compatible
Forum rules
I like the Contis 5000 as well. Actually, I run the non-tubeless ones tubeless. After a week or so, the sides were airtight.
They are on my rims because it was friggin impossible to put the Schwalbe Pro Ones on that I had intended for this particular wheelset. And that, it seems, happens to others as well - Bike24.de accepted the Pro Ones being returned without any hassle.
Very interesting! What sealant are you using? Do they stay on the rim when they deflate?SchallUndRauch wrote: ↑Sun Feb 10, 2019 2:04 amI like the Contis 5000 as well. Actually, I run the non-tubeless ones tubeless. After a week or so, the sides were airtight.
The DynaPlug Air was originally released a while ago, but it didn’t support road bike tires...the outlet was placed too high on nozzle. If you buy one, make sure you get the road bike kit.
I just carry a DynaPlug Racer and the smallest pump I could find (Topeak Micro Rocket.)
thanksTobinHatesYou wrote: ↑Sun Feb 10, 2019 10:11 amThe DynaPlug Air was originally released a while ago, but it didn’t support road bike tires...the outlet was placed too high on nozzle. If you buy one, make sure you get the road bike kit.
Trek Emonda SL6
Miyata One Thousand
Miyata One Thousand
Jarno measured them and they were the same. 0.55mm.
Mounted GP5000TL 25mm on Roval CLX 50 DISC (internal 20,7mm, external 29,4mm). It did hold the air without sealant by using floor pump. When deflated it did not stay on the rim but with sealant that might not be the same. With floor pump it did hold the air again easily.
I measured the width right after installation:
4,95bar 26,6mm
5,98bar 26,8-27,2
7,04bar 27,1-27,4mm
The width wasn’t exactly the same on different sections of the tire but that might settle after a while?
I am from Finland so will be testing outside on april.
4,95bar 26,6mm
5,98bar 26,8-27,2
7,04bar 27,1-27,4mm
- in the industry
- Contact:
No one should be advocating running a road tyre that's not tubeless, tubeless and saying after a week it fine. The bead on the non tubeless tyre is not the same and that's were the issue can be. If your going to run tubeless great tlget a tubeless tyre. If your not great then use frickin inner tubes in the non tubeless tyre.
