Forum rules
TobinHatesYou
by TobinHatesYou on Fri Dec 14, 2018 9:29 am
Monkeyfudger wrote: ↑Fri Dec 14, 2018 9:24 am
I’d be willing to bet the guys getting a lot of sidewall cuts are running their tyres fashionably soft and maybe also not quite being honest with themselves about their weight
it’s getting to be the same in MTB, dudes running ridiculously soft tyres for the gripzzz but pinch flatting *f##k* out of tubeless so we’re now seeing foam inserts :eyeroll:
The opposite. Almost all of my punctures occur when I am going a PR and I inflate the tires to higher than my normal pressures. Deflection when dealing with harder objects is good.
Marin
Hexsense
by Hexsense on Fri Dec 14, 2018 5:24 pm
Opposite is true. Soft tire deform around object with ease. High air pressure add tire wall stress and stretch it. In turn Tire deform less and push smaller surface at higher stress against the object.
If you run 0 psi over a knife, it may not even get cut (but it surely get pinch flat
dvq
by dvq on Fri Dec 14, 2018 11:28 pm
You callin' me fat, pal?
Monkeyfudger
by Monkeyfudger on Sat Dec 15, 2018 12:27 am
Probably. Yes. Sorry?
I wasn’t referring to a tyres ability to deform around punctureeee things but the extra wear on the sidewalks likely introduced by the decrease in pressure and also the increase likelihood of the sidewalk being closer to pointy things.
bm0p700f
- in the industry
by bm0p700f on Sat Dec 15, 2018 2:08 pm
I use PTN inserts but not to avoid pinch flats, I never get those. I dont even puncture my MTB tyres. I use them to get more grip and improve the handling over very rough ground (the lower pressures and the extra firmness the insert adds stops the front wheel doing pinging off in ruts and other obsticles) . Its like I have a bigger tyre and give i run 2.1" 29er tyres thats useful. Also one of my bikes is rigid and its like having suspension in the tyre. You dont get inserts like many others. They are marketed in the wrong way. rim defense and pinch flat protection is a side effect of there main feature that though depends on the foam used and how big it is.
Even in the tubeless MTB world ignorance rules.
bm0p700f
- in the industry
by bm0p700f on Sat Dec 15, 2018 2:14 pm
AJS914 not true, some race oreintated tyres do seem to better than other in flinty area. conti for me I am talking the GP4000s, GP 4 season and the gator skins have never lasted long for me. Even the gator skin hardshell got its side wal sliced up. The other tyres I use dont seem to do this I head down some really shite roads.
AJS914
by AJS914 on Sat Dec 15, 2018 3:39 pm
So maybe we can just conclude that these sidewall cuts are geographic/geologic depenendent. I was honestly curious as I haven't had a single sidewall cut on a GP4000 in 10K+ miles.
RocketRacing
by RocketRacing on Sat Dec 15, 2018 4:31 pm
bm0p700f wrote: ↑Sat Dec 15, 2018 2:14 pm
What “other tires” do you use?
I am thinking a gravel tire would be a better choice for you than gp4000 or similar performance road tires.
You don’t take a race slick down an icy road and then complain that grip sucks... wrong tool for the job imho.
Dan Gerous
by Dan Gerous on Sat Dec 15, 2018 5:08 pm
RocketRacing wrote: ↑Sat Dec 15, 2018 4:31 pm
Gotta agree to have the right tool for the job. Something like Panaracer's GravelKing (the slick ones) could be a good choice. I have a pair and they roll quite well for a tough tire that has a bead to bead protective belt, they're pretty grippy but pretty tough. Mine are on my endurance/road/gravel bike so I went for the 700x32, a bit heavy but they don't slow me down too much even on fast long road rides, they make them in lighter 28 and 26 widths to fit road bikes, their weights are comparable to Vittoria Corsa G+...
bm0p700f
- in the industry
by bm0p700f on Sun Dec 16, 2018 7:50 pm
So your trying to tell someone who rides 450km a week without issues, mostly on crappy, gravel and flint strewn country lanes, even though I don't have problems. Today I was on IRC Roadlites tubeless tyres.
I am using the new GP5000 tubeless but it's too early to tell how they will hold up.
RocketRacing
by RocketRacing on Sun Dec 16, 2018 8:40 pm
Hahaha. Very true.
I joke that a modern gravel bike is just a front fork away from an xc bike 10 years ago.
That being said, many modern road bikes have plenty of clearance for some pretty tough (and wider) tires.
Also, schwalbe has a pretty bad rep in my area. A few gens ago rhey took things a bit too far and punctures/tears were common.
Given where you live, conformation bias/bad luck aside, could temperature be a factor? Some rubber compounds get too fragile under the cold, or too soft in the heat. Just thoughts, as i do not think there is a magic secret.
bm0p700f
- in the industry
by bm0p700f on Sun Dec 16, 2018 9:17 pm
I edited after posting. MTB riders have been doing gravel long before it was called gravel and Paris Roubaix riders have been doing extreme gravel since day zero. The first bikes where gravel bikes. Gravel tyres therefore have been around along time. They're called road tyres.
The biggest tyre I can fit under my mudguards is 28mm wide and 25mm tall.
LeDuke
by LeDuke on Mon Dec 17, 2018 6:35 am
Monkeyfudger wrote:I’d be willing to bet the guys getting a lot of sidewall cuts are running their tyres fashionably soft and maybe also not quite being honest with themselves about their weight
You know that some of the top XCO racers in the world are running inserts, right?
45kg women running inserts on 300g carbon rims. For traction AND rim protection.
