New Out-front mount for Extralite Hyperstem
ccache
by ccache
Just found this on the Extralite website!
Looks like they're working on a new bolton out-front mount for their Hyperstem (replaces the existing two front clamps).
ETA Jan-2019
15 grams claimed
Carbon-fibre arms and insert
VTR1000SP2
by VTR1000SP2
What the heck... I literally sold my Hyperstem 2 months ago because there wasn’t an elegant enough solution for it.
Looks good.
bilwit
by bilwit
VTR1000SP2 wrote:
Tue Nov 06, 2018 11:10 pm
Looks good.
I almost did the same but ended up using a less-than-ideal offset bar mount instead.. I'd defiinitely give this a shot.
Mep
by Mep
This is perfect, love the thinking from Extralite
tabl10s
by tabl10s
Much lighter than the ENVE product.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
refthimos
by refthimos
I think I'll stick with my simple 14.4g Raceware mount.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
NiFTY
by NiFTY
When are mcfk gonna manufacture one
Imaking20
by Imaking20
In!
mike
Resident Pro
by mike
i like it. unfortunately i also sold my extralite stem..... :evil:
mrlobber
by mrlobber
NiFTY wrote:
Wed Nov 07, 2018 12:14 pm
This.
It looks like they've really stopped innovating, their products are now "medium" weight, compared to other mass and individual producers (Schmolke, Darimo), but still priced relatively very high :noidea:
Brilliantly elegant idea from Extralite (although it looks like you'd need to purchase new front plate along with the mount)
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
NiFTY
by NiFTY
Yeah mcfk have really changed their approach it seems. Maybe their is a market for medium weenie products but i imagine most will steer for the others you have listed. I imagine their stem is probably their best seller.
ironman1
by ironman1
I e-mailed Extralite as to when these would be available and no response. Wondered what others have tried with the extralite stem. I thought about the F3 out front mount but wondered how secure it would be. One would have to switch out the 5mm bolts that come with the F3 and most other out front mounts to Steel 4mm bolts for the Extralite.
I've thought about a bar clamp on but all the ones I've seen are for the right side of the stem and because my climbing switch is there I want one on the left, purely esthetics I know.
RocketRacing
by RocketRacing
refthimos wrote:
Wed Nov 07, 2018 5:59 am
This, though i find the mounting is not as locked into position as other mounts.
sychen
by sychen
I also emailed extralite recently to ask if a gopro mount option for lights and cams is part of their mount.. They replied they are looking into it but no dates or commitments.
I also use the F3 mount (not on extralite stem) and probably wouldn't want to try a 4mm bolt as it's not recommended. Would also have to source extra long 4mm bolts for that to work.
