Stages power meter repair help
onemanpeloton
by onemanpeloton
Hi guys
Picking your brains here because my gen 1 stages 9000 crank arm is out of warranty and stages only want to sell me a new one.
Basically the power meter over reads power massively. Apparently my 40 min commute has avr power of 1000w and max of 2000w. This should be closer to 200 and 1000 most days.
The stages unit has a small crack in it which i assume has let some water in. Normally i would write it off in this situation but the power readings are consistent albeit wrong.
Any suggestions? Thanks
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
bikeboy1tr
by bikeboy1tr
I assume you have been doing the Stages updates whenever they come out. If I get caught in the rain I usually remove the arm and pull the battery and then store it in a bag of rice. I know with mine if I get it wet it eats batteries up at an alarming rate.
"Life is like riding a bicycle. To keep your balance you must keep moving"-Albert Einstein
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
bilwit
by bilwit
onemanpeloton wrote:
Mon Nov 05, 2018 11:11 pm
sounds toast to me. If the readings are consistent as you say, doesn't the phone app let you specify a manual offset?
NiFTY
by NiFTY
It sounds cooked.
alcatraz
by alcatraz
Doesn't sound good. Did you redo the calibration in your stages app and garmin to be sure?
To keep moisture away you need to put a piece of plastic over the whole power meter and then wrap electrical tape over it all. Change the battery before you do.
/a
FIJIGabe
by FIJIGabe
I sent one back, recently, and they replaced the PM on my crank arm for $200, and now I have a warranty on that unit. Just a thought.
Emonda SLR (under construction), Madone 5, Cobia. I own a lot of Treks.
onemanpeloton
by onemanpeloton
thanks for all the replies.
I admit it doesnt look hopeful but I still thought that, given its consistency, it might be salvageable.
I've updated the firmware and done a zero offset a few times, nothing changes.
im in the UK. I contacted stages who put me in touch with the UK distributor and they said they wouldnt replace the PM on my crank even if I paid for it. Shame really.
2017 Giant TCR Disc
2015 Giant TCX
FIJIGabe
by FIJIGabe
That sucks. Sorry to hear that the local distributor would do that. You don't happen to have any relatives in the US, do you?
onemanpeloton
by onemanpeloton
sadly not! it's a shame that the distributor wont help, given that stages offer this service.
may I ask how much you paid to have yours fixed? if its cheap enough then maybe i can find a US friend!
2017 Giant TCR Disc
2015 Giant TCX
FIJIGabe
by FIJIGabe
It was $200 for the repair, plus shipping to them (they covered ground shipping back to me).
2lo8
by 2lo8
That seems about right for Stages customer service. Even when it came to known design flaws on the gen 1s, they would claim there was nothing wrong with the design because it lasted the life of the product, meaning the duration of the warranty period.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
