Trek emonda SLR10H2 VS CANYON ultimate Evo .
Coinmonger
by Coinmonger
Which one to pick ?Im confuse a bit could you guys explain to me diffrences? Those two are a top of the shelves and im wondering on which frameset i should pick for sub 5 build.
alcatraz
by alcatraz
Reasons to avoid trek.
bb90 = 24mm spindles = heavy
trek seat masts = 150gr proprietary part
These details have been bugging me.
robertbb
by robertbb
Both come out of the same factory, Quest composites, and probably use a similar carbon grade to reach the weights advertised. Build quality will therefore be the same, so pick the one that has the features (see Alcatraz' post), geometry and finishing you like best.
iamraymond
by iamraymond
The oversized steerer tube on the Canyon will limit your stem choices, but that would still be my pick.
Cemicar
by Cemicar
Why H2, btw? If your main concern is weight, go ahead with H1.
alcatraz wrote:
Fri Nov 02, 2018 1:10 am
You're right but the author is torn between Trek and Canyon. With BB86 I don't think so many can use a 30mm spindle crank comfortably. And Ultimate frameset comes with a weird seatpost which I fathom most people end up using.
wheelsONfire
by wheelsONfire
PF 86 (Canyon as an example) is also not made for 30mm axle
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
mdeth1313
by mdeth1313
wheelsONfire wrote:
Fri Nov 02, 2018 1:29 pm
My Wilier zero.6 uses PF 86 and I run a clavicula crankset on it - no issues. PF4130.
Speedplay is the devil!
wheelsONfire
by wheelsONfire
Pressfit 46*30, would accept pressfit 46*24 also.
I haven't seen any 41*30 pressfit, but heard of. It seems those bearings should be pretty small?
Anyway, it's really idiotic to build a frame around 41mm as the bearings are not as durable as 46mm shell.
Bikes:
Ex bike; Vial EVO D
mdeth1313
by mdeth1313
wheelsONfire wrote:
Fri Nov 02, 2018 9:26 pm
What pressfit do you have when you fit a 30mm axle in a 41mm version?
THM's own. I've heard rotor's sucks but Hope makes a decent one.
KCookie
by KCookie
Correct THM have their own, plus AITA and I had a C-bear PF41-30 fitted in my PF86 frame yesterday.
wheelsONfire
by wheelsONfire
I guess it's made as a last resort option. But what the reason for going this route is i don't understand. It's many frames using 41* BBs.
When i look at a new frame, every option like this is off the list.
Bikes:
Ex bike; Vial EVO D
RZack89
by RZack89
Pay attention to the geometries: Trek H2 and Canyon are so different, consider this.
Attermann
by Attermann
In 4130 you press the bearings directly into the frame, so they are bigger than bsa bearings with outboard cups
wheelsONfire
by wheelsONfire
Aha, so the bearings are same size balls?
Looking at Campas (Ceramic speed) T45, it looks as a standard, with shell etc.
Bikes:
Ex bike; Vial EVO D
alcatraz
by alcatraz
I'm guessing pf41 (bb86) uses normal shimano standard bearings 24x37x7. Those leave 6.5mm for two races and balls.
4130 however can with bearings directly in the frame only do with 5.5mm for two races and balls.
However people do report no problems running 4130 so, there could be something new to learn about them. Interesting..
Maybe they run bearings in two tracks. That could help spread the load. Still a bit annoying that a bottom bracket might have crazy small bearings. Common sense tells me it needs to be built at a much higher standard to be as reliable as a common bearing.
