Stripped RD hanger bolts. Where can I get better bolts?
wheelsONfire
by wheelsONfire
Loctite 222 (small) should be sufficient.
The bond brakes at 6Nm. A stronger agent requires more strengh to release.
You shouldn't torque it much more so no need to use a stronger agent.
Btw, i have used 222 at motorcycle components, never any issues.
Bikes:
Open *UP* (2016.04.14)
joejack951
by joejack951
deepakvrao wrote:
Fri Oct 26, 2018 3:35 am
joejack951 wrote:
Thu Oct 25, 2018 3:16 pm
Also, I offered in your other thread to help out with replacement screws but you never provided any measurements. Per your pic they appear to be in the 6-8mm long range with a hex recess. Can you confirm? I have a handful of 18-8 stainless M3x6mm long socket head flat screws and would be happy to drop a few in an envelope for you. They’d solve the problem IF the issue is corrosion.
Thanks. I really appreciate that. I do, but I dont know what specs to provide? Also, I live in India, so while your offer is very generous, I'm not sure that you could post them here?
Since you provided a picture I know most of what I need to know. Just confirm the overall length. Are you in an area that has reliable postal service? That will be by far the cheapest way to send these.
joejack951
by joejack951
wheelsONfire wrote:
Sat Oct 27, 2018 8:57 am
I am not sure why there is all this talk of Loctite. The screws are not coming loose on their own. My guess is that they were installed dry and slightly galled against the titanium. Any new hardware should get a generous coating of grease or ideally copper antisieze.
Calnago
In Memoriam
by Calnago
Threadlocker is pretty much universally used for these screw because of their small size, small number of threads engaged, and low torque that is applied to them. It just ensures they don’t come loose or seize up. It is far more appropriate than grease in this application.
joejack951
by joejack951
Calnago wrote:
Tue Oct 30, 2018 4:10 pm
I see your point but I typically won't resort to Loctite unless I'm really having an issue with a fastener. In the OPs case, the screws are staying plenty tight and it sounds like he removes them fairly regularly. Grease/anti-seize seems appropriate to me, but the correct Loctite would also suffice at least for a few R&R cycles.
deepakvrao
by deepakvrao
joejack951 wrote:
Tue Oct 30, 2018 7:59 pm
Yes, makes sense. Thanks.
