Campagnolo 12s Maximum Smoothness shift cable set
Any idea if the new cables can be ordered without the houses? I am planning to replace the rear derailleur cable (the houses look fine to me, I think they can last another season) and I would like to try these new "maximum smoothness" cables but I only find them as bundle (and super expensive)
Could you explain what has changed?
I understood that the inners have more fine strands (like jagwire elite)
has the housing changed as well?
Typo? CG-FRD700 seems to be the right code (searching for that shows a Campagnolo PDF but only 2-3 retailers, e.g., thecycleclinic.co.uk and www.coloradocyclist.com/campagnolo-ergo ... -cable-set)
Does anybody know if you can get single cables? I’m trying to get just one cable. Had to snip my front mech cable and went too short
If you only need a single cable, just get jagwire elite ultra-slick shift cable. I use both the new campagnolo maximum smoothness and just same.
https://jagwire.com/products/inner-wire ... inner-wire
But i prefer the new campagnolo housings than the jagwire
Thanks a bunch guys much appreciated! Any thoughts on running them with Nokon outers?
