School me on headsets
RocketRacing
by RocketRacing
Hi folks
Tonights reading is on lightweight headset options. Early on my reading list is eebrakes aer headsets (plastic bushings... ummm...) and extralite.
Any thoughts on good weight/reliability/cost options? I am not afraid of high end as prices do not seem that expensive in the relm of weigh weenism (i.e cheap/light/durable, pick any two... i will sacrafice cheap).
Thanks for any experience/input.
RocketRacing
by RocketRacing
Cane creek aer series ii seems to be on point.
alcatraz
by alcatraz
What about those fsa headset bearings with alloy outer rings. I saw somewhere they were around 25usd a piece. Replace both and you can save around 18gr in those two bearings alone.
morganb
by morganb
RocketRacing wrote:
Tue Oct 23, 2018 1:58 am
Hi folks
The new AER got rid of the plastic bushings.
kode54
by kode54
bottom bearings in headsets get beat if riding in wet weather and such. Chris King is starting to make bearings for inset headsets now. not nearly as comprehensive as Cane Creek's offerings. That said, I have mostly Cane Creek headsets in most of my bikes...with one Chris King headset. Both have been reliable but again, I repack grease at the end of the season.
not sure how much weight you can save with headsets. i pick reliable over weight.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
asiantrick
by asiantrick
Don't bother with light weight headset. They will crack on you. I choose reliability over weight any day.
Hexsense
by Hexsense
alcatraz wrote:
Tue Oct 23, 2018 8:13 am
I had that FSA bearings for a while. It literally disintegrated itself in my riding condition in 3 months. Like it felt weird then i remove fork to inspect and noticed that the bearing coming out in pieces, like top and inner part, then ball and retainer, and bottom part of the bearing.
For bottom bearing, i'd go all in for Canecreek's Hellbender bearings or Enduro stainless steel bearings (they make multiple versions, get the stainless steel one), whichever is cheaper. I'd guess Enduro Stainless steel would be cheaper for bottom bearing, as Canecreek literally price bottom Hellbender bearing twice as expensive as the top bearing.
Then you can save weight on top bearing, if you want to.
RocketRacing
by RocketRacing
Great replies.
Durable for the bottom, light for the top is the smart way to go i am sure. My logical brain said so.
Sadly, the logical brain kinda got beat down by rhe weight weenie brain a while back. Hahaha
I think i will be evaluating cane creek options. Series ii seems like the winning top choice. I will eval the needs for the bottom (60kg/130lbs rider, dry riding, some choppy pavement, and low miles as i divide time between mountain/gravel/road bikes) and make a cost/durability/weight analysis.
But lets be honest here, i think i can get away with a bit more reliability for the weight, even for the bottom... so i can see me chosing something that pushes the limit a bit.
tabl10s
by tabl10s
Deleted.
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
wheelbuilder
by wheelbuilder
I've been using the FSA Superlights mentioned above for a couple of years. I like them and they are very light. They are not durable however, as I have gone through three in 2 years. Keep buying them though.
beanbiken
by beanbiken
I also recently replaced my Izalco Max's headset with the FSA alloy bearings, so far so good but it is still only early days and of course time will tell. Think it saved about 20 grams on the pair.
BB
BB
Coffee & carbon
bm0p700f
by bm0p700f
Stainless steel is about the worst material for ball bearings there is. It pits more easily unlike harderened chrome steel. The longevity of a stainless bearing is more to do with the grade of the balls and the smoothness of the races. If the stainless balls were replaced by grade 10 chrome balls it would last even longer. Sadly stainless sells with bearings so bearing manufacturer end up reinforcing the myth.
It not the brand name that makes the bearing good it's the materials used and specification which is not shared. Hence myths like stainless is better perpetuate.
Hexsense
by Hexsense
I kinda know they aren't as strong as normal steel just didn't know it's that far behind. I though it's still way stronger than aluminum bearing and still great for the task, right?
In my salty area near the sea in addition to hefty amount of my sweat and salty energy drink, any bit of rust resistance (in addition to packed grease) is apreciated.
I had some bearing that leak out rusty color stain. I don't want that again anywhere on my bike.
