I know there's been a few threads where 3t bars have a bit of a 'crease' in the clear coat from clamping - usually no problem. The clear is obviously quite thick around the clamp, and I'm not too worried about the stem outline.
But with my bar, it looks like a bit of a gouge level with the max torque info. As a minimum it's gone through the paint... More than cosmetic? Your thoughts please. eBay purchase - keep or return?
Aeronova clamp - damaged?
I got an Ergonova from eBay a few months back that had a much bigger dent than that. I ended up returning it.
https://weightweenies.starbike.com/foru ... p?t=152258
Since then I bought a new Ergonova and torque it to 4nm. No indentations so far.
I wouldn’t worry about those small marks. You’re going to sand the bar down anyways right?
2010 Orbea Opal 54cm
5.97kg
5.97kg
I've witnessed a handlebar break, so if it were me I'd inspect the entire contact area under magnification. Try and determine if the indentation goes beyond the clearcoat and into the carbon.
If you have any questions, I'd take it to a pro repair shop or send it back for a quantitative determination.
