alcatraz wrote: ↑Wed Oct 24, 2018 6:23 am
RocketRacing wrote: ↑Wed Oct 24, 2018 1:44 am
Of interest, i just got red wifli for my bike. The rear derailer came in underweight at 191g, so add the 24g battery and we are 215g (website says short is 239g with battery). Reviews said wifli was 12g extra! My compact crank with 170mm arms also came in really light also. On the same scale the hoods and front derailer came in withinf a gram of stated factory weights. Take the info fwiw.
Is it possible one of the sensors on that scale tray is defective? Like the weight changes a lot depending where on the tray the weiht is?
I had that happen to me once... just a hunch. Congrats to the great weights otherwise. Super jealous
Yeah, the shop scale looked like it had been around (i have two different scales at home... probably why i am on the weight weenie forum).
I measured twice, and other components were right on spec for weight... but i agree that it is unlikely for a big company like sram to be sooo far off on component weight, even if online reported weights are for longer cranks and 53/39 chainrings. If the rear derailer and cranks/rings were updated and lightened... i am sure sram would announce it with bells on!
Either way, i am happy with the setup.
Edit: i looked back at some of my before/after full bike weight numbers post etap. Based on reported 6870 groupset weights, and factory sram numbers (420g for 170mm 34/50 that i found)... i expected 490g savings for the swap, but as i kept ultegra brakes, my expected lossed were 412g.
I got 466g for the crank setup and 34/50. 54g under. I was 24g under for the rear derailer. So my red groupset was 78g lighter than expected factory numbers. The casette, chain, hoods, front derailer were also very close to weight spec online.
My final bike weight post swap said i lost 540g, or 128g more than expected from listed sram numbers. No two scales are accurate, but best case, my red setup was 78g lighter (54g crank, 24g derailer).
But we still have 50g of extra weight loss to account for. I think that was either scale error (same scale used at my home for before and after red weights), or.... more likely the spacers felt used to make shimano spindles work with bb30... something i forgot to weigh, and could be the difference.
Long story short... i think my red cranks and derailer are light. Or maybe my ultegra was heavy. I can check...
