THM Clav SE cranks with eTap?
tomriddle
by tomriddle
Stick with SRAM chainrings ?
Praxis or Extralite rings ok?
Building an etap build .. done but would like to use my THM cranks and was wondering if there are any hang ups or issues I can avoid.
rexyi1990
by rexyi1990
Hi, mine is eTap with THM SE cranks w/ Carbon-TI chainring, the combo works fine for me
sungod
by sungod
generically, the only thing to watch for is clearance between the limit screw and inside crank arm during the 'overshift' when changing to the big ring (if it occurs then just grind down the other end of the screw to shorten it)
since fitting etap in march 2016 i've used old sram red, praxis works, and current red yaw rings, all shift fine, zero chain drops
tabl10s
by tabl10s
Have Classic with Quarbon's and no issues(haven't used my SE yet).
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8:
13.04lbs/5.915kg
2018 S-Works SL6(shooting for 11lbs).
Johnny Rad
by Johnny Rad
rexyi1990 wrote:
Sun Sep 30, 2018 4:45 pm
Looking forward to matching your crank/ring set-up one day... :beerchug:
ride1970
by ride1970
Using THM SE with etap and praxis, works great. But will he changing to Carbon Ti at some point
mrlobber
by mrlobber
My Etap setup after 2 months of working just fine destroyed a Carbon Ti outer ring - one of the teeth / carbon core joining pins was ripped out and subsequently the metal teeth part broke.
Clavicula SE with Extralite rings, on the other hand, on Etap have been working fine.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
