Does direct drive trainer damage frame?
biwa
by biwa
To save time during the week, I train indoor using a Elite Drivo with one of my two Ti road bikes (only ones I have). I also ride both bikes outdoor on weekends.
I'm not a heavy rider, ~66kg, and pretty much all my trainer rides are intervals. I wonder if the clamping/force on the frame by the trainer will affect the frame (e.g. the chain/seat stays) adversely over time?
Ravnsnaes
by Ravnsnaes
The short answer is NO, using a direct drive trainer will not damage your frame. But in some instances, using an indoor trainer could void your frame warranty.
cunn1n9
by cunn1n9
The short answer is YES it can. I have had it happen to me in a Kickr.
If you stand up you can create a motion whereby the bike if not fixed by the rear dropouts would naturally rock side to side. This is most exacerbated at low cadence and high torque. If you do this the motion is restricted by the bike being fixed at the dropouts however the force is still present and is applied as a twisting force that will break down the carbon dropout if done enough. Mine did this however I had it fixed by a very skilled carbon repair person.
I since sold the Kickr and would only ever use an old frame I didnt care about in a Kickr or use an alloy frame.
If you just sit and pedal at a optimal cadence so as to do create the side to side motion you will probably never have a problem.
kgibbo1868
by kgibbo1868
I would say if you don't clamp the frame tight enough you can have some issues. I had my bike come out of my Kickr sprinting (1200W) and my hanger bent a bit. I think it could have done more damage, but I was lucky and now I clamp the frame a bit tighter and am careful not to rock side to side while sprinting.
Pain is my friend!
ergott
by ergott
cunn1n9 wrote:
Thu Sep 27, 2018 12:12 am
What frame?
TobinHatesYou
by TobinHatesYou
I routinely do 1200-1300W 1s and 1100W 5s, 900W 15s power on an aluminum alloy road bike attached to a CycleOps Hammer. It has shown no signs of fatigue and a carbon composite bike should be less susceptible to fatigue than an alloy bike.
mattr
by mattr
There have been a few reported failures on here, and other forums that i've seen. Probably less than 20 in the last 3 or 4 years.
*Usually* very lightweight frames and very rigid trainers. But not really a big enough sample to draw any meaningful conclusion.
Quite a few manufacturers have caveats in their manuals and exclusions in warranty documents as well.
You've got to decide if you think it will be an issue.
Quite a basic run through of the loads will show that they are significantly different to those you see on the road, not necassarily bigger, just not the same. Which may or may not be a problem. Depending on what margins there are on the frame design.
silvalis
by silvalis
Sounds like you need a trainer rocker plate (eg, a rockit board/DIY)
Chasse patate
mattr
by mattr
Or a Neo.
silvalis
by silvalis
Or that fancy bike treadmill
Chasse patate
corky
by corky
*cough* rollers *cough*
mattr
by mattr
full effort/1000+ watts on rollers?
No thanks.
eric01
by eric01
Get a beater bike off of eBay and use it dedicated for the trainer. Weight, aero and component quality doesn’t matter on a trainer
AX Lightness Vial Evo, Carl Strong Titanium
biwa
by biwa
So it seems like as long as you don't rock it left and right on the trainer and keep the whole thing relatively stationary laterally, then you should be fine..
TobinHatesYou
by TobinHatesYou
Sometimes in sprints I make my trainer rock and even bounce the whole system. Before I added foam gym flooring, my whole set-up would walk itself forward about half a foot in 15s sprints. Frame is still fine. If you do none of these things, you’re especially fine...
