S-Works chainset not spinning freely
PaulH
by PaulH
I removed and cleaned my s works chainset today and noticed when it spins without the chain on it , it only manages two-ish revolutions, whereas my dura ace on a different bike spins for ages, I have torqued everything to spec and set the preload correctly , is this normal with s works or is it the new grease slowing things down ?
sennder
by sennder
Fresh grease in BB bearings takes a while to spread out. That is why new BBs are almost always "stiffer" than worn in but well maintained BBs. I'm assuming that you regreased the bearings.
--Sennder
NiFTY
by NiFTY
Sounds like a BB issue unless you have accidentally increased preload. Did it spin well before you removed it?
alcatraz
by alcatraz
Sorry but free spinning cranks 2 turns doesn't really indicate that there is a problem.
While the crank is off next time, take a moment to feel the bearings.
Another way is to put your ear to the seat or frame and spin the crank without a chain. Any grit will usually be heard.
Usually there is a balance between grease thickness and bearing maintenance intervals.
Check that your wavy washer isn't completely compressed. Also it's possible the bb shell doesn't line up perfectly left to right. Hambini has tested bb shell alignment on several frames and has some interesting data.
If your bb bearings can come out of the shell quite easily you might have some ovalization going on, by which you should probably reinstall them using some appropriate retaining compounds. If your bb shell is metal and not carbon, this would be less likely.
PaulH
by PaulH
They aren’t grinding and there is no wavy washer on my version , guess it must be the new grease
alcatraz
by alcatraz
Oh? What kind of preload system do you have? Hmm
PaulH
by PaulH
Not a preload but a colllar with Allen key bolts on it
ryanw
by ryanw
Too many spacers, wrong preload.
Mine spins for 20-30 seconds.
PaulH
by PaulH
Ok cheers going to try again now
PaulH
by PaulH
Two spacers stuck together , spins for ages now many thanks for your help.
