caad12 bb30a crankset compatability
scfc151
by scfc151
hi all.
im trying to find a compact crankset to replace my 52/34.
im quickly learning that bottom brackets are a mind field. ideally i want to find a bb30a replacement for a straight swap rather than using converters etc.
can anyone tell me if an fsa si crank would fit?
i currently have a gossamer crank but struggling to find one in good condition
alternatively a list of compatable bb30a cranks would be mega useful.
thanks
Valbrona
by Valbrona
Think FSA BB386 and Rotor 3D+.
djel
by djel
I'm using a Rotor 3D+ crank with a P2M spider and Praxis rings. You can also use the 24mm spindle version of the crank if you want. As mentioned FSA BB386 will work too and of course the SL/SiSL sets from Cannondale.
Don't quote me but if you go with a 24mm spindle, you will have more options for the bottom bracket itself rather than using the standard 2 piece bearings pressed into the cups.
