SRAM Red eTap FD chain drop
bikeboy1tr
by bikeboy1tr
I run the Rotor rings with my etap and found that I would get more chain over the outer with the oval rings and its always in the middle of the rear cogs when it does happen. I also found that if I run the 38 Rotor inner mixed with an Absolute Black 52 outer that the jump from one isnt as big, as the Rotor has more ovality if thats a word than the Absolute Black. I believe the Oval rings present more opportunity for that fd to dump the chain over the outer. I normally try to shift the fd at a certain angle in the pedal stroke to avoid that situation.
Also when I ride the rollers it seems non of my bikes shift small to big ring as well as out on the road and I would imagine the trainer is not that much better for shifting fd. I know when setting up the shifting in the shop and you actually ride outside it never seems to be the same.
One other thing I have been thinking is would a 12sp chain work better with the fd to keep it from dumping? My thoughts are not likely as the fd still needs to be set tight and maybe wouldnt make the difference. I think I might try it on my next chain to see if its worth doing.
"Life is like riding a bicycle. To keep your balance you must keep moving"-Albert Einstein
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
DaMaDo
by DaMaDo
pdlpsher1 wrote:
Thu Feb 21, 2019 8:02 pm
I suggest that you get your bike back and call Sram yourself. If the shop has to call Sram then the shop is just an unnecessary middleman.
I thought that SRAM won't deal with consumers, only retailers.
wheelbuilder
by wheelbuilder
DaMaDo wrote:
Fri Feb 22, 2019 2:50 am
Correct. Sram is not going to offer any help to the end user. They are responsive and fast when dealing with dealers though.
TobinHatesYou
by TobinHatesYou
wheelbuilder wrote:
Fri Feb 22, 2019 6:42 am
For major service / warranty issues, I'm okay with it. On the other hand I've just lost the little rubber cover/plug on one of my HRD calipers (flew off on a ride,) and it seems silly go through a dealer for such a small item.
alcatraz
by alcatraz
Bit offtopic but how can I ensure I won't break the battery tab on my new etap batteries? What should I look out for? Clean surfaces?
Thanks /a
TobinHatesYou
by TobinHatesYou
alcatraz wrote:
Fri Feb 22, 2019 8:10 am
Thanks /a
A tiny bit of superglue between the two "halves" of the battery plastic at the tab.
Gearjunkie
by Gearjunkie
Good tip, thanks Tobin.
Can you please post a photo showing where you mean?
sfo423
by sfo423
Quick Q; I am building an F10 disc w/eTap and was interested if most are opting for a chain catcher (w/their eTap builds)...regardless if you have had drop issues or not.
TobinHatesYou
by TobinHatesYou
sfo423 wrote:
Thu Apr 04, 2019 4:02 pm
I would use a chain catcher with any groupset. You can’t pick up a chain that drops inside just by shifting the FD to the outboard position. Dropping a chain inside can also mangle your frame.
However inside chain drops aren’t the problem with eTap...it’s throwing the chain up and over the big ring that’s the problem because Yaw sucks and eTap’s temporary overshift makes it even worse.
ArtV
by ArtV
Chain drops have been a problem for me on long rides with steep hills and lots of front chainring shifts, even on mechanical Shimano systems. It may be a bit worse with Etap but I have done a full century with a bunch of front shifts on Etap with no drops. I went ahead and bought the Wickwerks Sentinel. It protects against the big problem, the drop over the outside of the big chain ring. One less thing to worry about.
ArtV
RedbullFiXX
by RedbullFiXX
Never have drops on etap, primarily a climber
Fine tuned I guess ¯\_(ツ)_/¯
ArtV
by ArtV
RedbullFiXX wrote:
Thu Apr 04, 2019 8:44 pm
What the heck? This is a thread for us 'chain droppers'. Are you just here to gloat?
:lol: :lol: :lol: :lol:
RedbullFiXX
by RedbullFiXX
ArtV wrote:
Thu Apr 04, 2019 8:51 pm
Have had drops on Shimano mech, does that count ? :lol:
bikeboy1tr
by bikeboy1tr
I have just installed a chain catcher on my wifes bike with etap as she has had all of her chain drops on the inside but with my bike the chain drops are always outside. The difference is her bike has short chain stays were mine has long stays.
For some strange reason (knock on wood) on my new Colnago and new Absolute Black chain ring I have only had the chain come off the outside once. Someone posted earlier on this thread that the cause of the problem is the cage is not deep enough so I am sure my luck will run out soon.
TobinHatesYou
by TobinHatesYou
Be careful with those Absolute Black chainrings. They don't have an anti-drop pin.
