Ritchey "integrated fork crown" ?
I just received a new Ritchey WCS Carbon Road Fork, model 2018 (https://www.bike24.de/1.php?content=8;p ... d%5B7%5D=1) for my road frame which is designed for an integrated headset (45 x45° Campa) in combination with Ritchey WCS drop-in headsets (SHIS: IS42/30) and a steerer diameter of 1-1/8".
There is a sticker on the fork saying "integrated crown race". However, there is no metal ring at the fork cone area, just carbon. Also, the fork cone area looks different on the Ritchey web page: https://eu.ritcheylogic.com/eu_en/headset-fork-crown. There is no metal ring but just a broad "carbon shoulder" (see attached pictures). Also, the lower drop-in headset does not sit well-proportioned on the lower end of the tube.
Would someone clarify for me what is going on here ?
Thanks,
Christoph
Thanks,
Christoph
- wheelsONfire
If i were you, i would mail Ritchey support and check this.
Perhaps you'll get a replacement fork?
Bikes:
Open *UP* (2016.04.14)
Please do check with Ritchey support but AFAIK the way you have it installed is correct. The 45deg carbon portion is the crown race, and the gap below the bearing is to avoid the frame and fork fouling on one another. I have two of these forks (rim and disc versions) and this is how they are installed. Much more elegant than hammering a metal race over a carbon steerer.
Google seems to suggest that there have been problems with some Swiss Cross framesets but I think that was to do with too little clearance rather than too much.
Thanks guys. I dropped a message at Ritchey support some days ago but did not get a reply yet. I will keep you up to date...
- wheelbuilder
Its an integrated crown race. It is right.
Thats how it should be. Integrated means that you don't need the separate component (crown race). Allows for a stronger crown (less sharp angles).pathohisto wrote: ↑Sat Sep 01, 2018 4:35 pmThere is a sticker on the fork saying "integrated crown race". However, there is no metal ring at the fork cone area, just carbon. Also, the fork cone area looks different on the Ritchey web page: https://eu.ritcheylogic.com/eu_en/headset-fork-crown. There is no metal ring but just a broad "carbon shoulder" (see attached pictures).
It'd probably look something like that on a conventional fork, with a separate crown race. What does the bottom of the head tube/bearing/fork crown look like when it's all pressed together?pathohisto wrote: ↑Sat Sep 01, 2018 4:35 pmAlso, the lower drop-in headset does not sit well-proportioned on the lower end of the tube.
petromyzon wrote: ↑Sun Sep 02, 2018 11:06 amand the gap below the bearing is to avoid the frame and fork fouling on one another.
When it is all put and pressed together it feels quite right, there is a 2mm gap between the steering tube and the plateau of the fork (as mentioned by petromyzon).mattr wrote: ↑Sun Sep 02, 2018 2:13 pmIt'd probably look something like that on a conventional fork, with a separate crown race. What does the bottom of the head tube/bearing/fork crown look like when it's all pressed together?petromyzon wrote: ↑Sun Sep 02, 2018 11:06 amand the gap below the bearing is to avoid the frame and fork fouling on one another.
I was just confused that the bearing sits directly on the carbon (never seen this) and that the area looks different as shown on the website and the tech drawing:
https://eu.ritcheylogic.com/media/itm/m ... 6-rake.pdf
^This. While there is no issue with the molded crown race (as was said, this has been the method of manufacture for a lot of forks for some years now, over 5 years for sure), I would double check to make sure you have the correct bearing for that fork as the bearing in the pic does seem to be sitting a little high.
IMHO there is only 1 kind of 45 degrees that comes in a WCS and a COMP version.
https://eu.ritcheylogic.com/eu_en/road-bike/headsets
I use this one:
https://www.bike24.de/1.php?content=8;p ... 7%5D=13485
I am getting more and more confused.
I received a reply from Ritchey support:
"The fork on RL.com is the same spec, however it was the previous version with a steel shim @ the crown race area, which was later removed.
It’s compatible with WCS DROP IN INTEGRATED LOWER HEADSET.
It will look a bit unusual with the integrated crown race and not having that as a separate part, however the dimensions will work out to be the same as complete.
Regards.
Ritchey International - Warranty & Tech. Dept."
Regards.
