MCFK stem problem
JanHoJan
by JanHoJan
i find my mcfk stem unable to lock the steer tube with the washer between the flange installed (fiber paste applied), but it locks tight without those washer at a torque of 4.5nm, is it ok to remove the washers? (the menu warned that the washers mist be in place)
hannawald
by hannawald
Ask the manufacturer, Mcfk talks with their customers, i contacted them couple of times.
ome rodriguez
by ome rodriguez
I’ve been riding mine without the washers and no problems. Just make sure to apply carbon paste and correct torque.
mortirolo
by mortirolo
mcfk_gebrauchsanleitung_vorbau.pdf
Further, also note that washers between screws and inlays at the tube clamp are installed at the factory.
Never install or use your new carbon stem every without these washers.
These washers are important and ensure the stability and safe clamping of the stem.
Marco Pantani - Momenti Di Gloria
tabl10s
by tabl10s
Exactly where do they go? The LBS can't figure it out.
2016 Orbea Orca OMR: 15.0lbs/6.804kg...😐 | 2016 Rca: 11.07lbs/5.048kg...😭 | 2015 Pinarello F8: 13.04lbs/5.915kg...😩 | 2018 S-Works SL6: 12.04/5.625kg... 😥
spdntrxi
by spdntrxi
tabl10s wrote:
Tue Sep 11, 2018 12:40 am
I presume you mean the (2) washers.... they go in the split where the stem is connected to the steerer tube.
tabl10s
by tabl10s
spdntrxi wrote:
Tue Sep 11, 2018 1:01 am
Found it.
Thanks.
JanHoJan
by JanHoJan
qwe23ty wrote:
Sat Sep 15, 2018 9:09 am
My friend ride without washers. No problem.
thx for reply, i will go without washer too
