Vespasianus wrote: ↑Tue Jun 23, 2020 2:30 am
roadchallenge wrote: ↑Thu Aug 22, 2019 5:42 pm
gorkypl wrote: ↑Thu Aug 22, 2019 10:23 am
So I have a small update on this.
I think it's indeed impossible to bleed the brakes using the Campy procedure. Every time I pump the brake lever while pulling the bottom syringe, the air bubbles appear in the bottom hose - I think the air might be coming through the master cylider bladder or the caliper o-ring.
However, I spent the whole evening, bleeding using procedures for Hope, Avid and Sram brakes, also unscrewing the caliper and gently tapping and rotating it to eliminate any trapped air. I think I made it to a point where there is no air in the system.
However, the pistons still move in a very uneven way - the one on the side whithout brake hose is much slower.
So I thought I'd take a look at the rear caliper, which was not touched by me at all since being bled by Campagnolo Pro Shop. And guess what - it is even worse. One piston almost does not advance, while the other one (the one on the side with hose) moves easily.
Of course I exercised the 'sticky' one multiple times, cleaned it thoroughly, lubricated with oil - no effect. Even removed the piston completely (by pumping it totally out of the caliper) to clean it. Still it does not move even closely to the other one.
I think I might start a separate topic on this, as quick googling shoeed it's not a Campagnolo-specific problem. However, I have to admit I'm already so tired of this, that I almost start to regret removing fully functional Ultegra Di2 and putting Campagnolo Record on this bike. It is definitely more beautiful, but the amount of troubles almost kill the joy.
Yeah video doesn't work... Man that sucks, thats my experience too, I don’t bother with lazy pistons though, I just hack them with paper trick, they move 0.6mm when pressurized anyway, so move fine after all setup, i’m 100% convinced air comes in at the shifter (not through o-ring at the port) but at the master cylinder inside, the only way to stop introducing is to not press shifter all the way and stop “pumping”, I just finish off by sucking and pulling until you don’t see any bubbles coming out., then close caliper port and see if shifter rock solid, if not then more sucking/pushing, takes me now 10-20 min for full re-bleed.
So, I am in the same boat as you guys. The back brake was really easy to bleed and install. There is no drag and the wheels spins freely. Firm feel and strong power. I pretty much only did the lever pull once of twice and did the push pull until no bubbles were observed.
The front brake is just a disaster. Just massive amounts of contact between the rotor and the pads. I can push the pistons back with the yellow tool and the bleed block - and do the card trick but the minute I remove the card and pull the lever, the pads contact the disc and basically stay in contact. Really frustrating. I have 15+ years with mountain bike disc brakes and don’t think I ever spent more than 30 minutes on a bleed. This has been 3 days of hell. I have the pads without the spring.
Part of me is thinking of draining all the oil from the front brake and restarting from scratch but don’t think that will make a difference. However, I am open to any ideas.
Does it rub on both sides of rotor or just one? Does it rub like constantly or just ping because you rotor slightly untrue? All campy rotors are untrue by the way, thats why it bitch to setup.
Don’t drain you’ve done everything right, Campy discs are bitch, you either need to true your rotor or do this:
1. Backoff pads/pistons to 0 position.
2. Bolt down caliper so it move only sideways no wobble so you can let it clamp on rotor without bending rotor.
3. Squeeze pads on rotor, it should give you pretty even pistons pushed out on each side.
4. Align caliper by eye (put piece of paper on the floor so you can see white space between pads and rotor). Card trick wont work, campy spacing is too small.
5. If it rubs on one side you can rebalance pistons by using tape trick/piece of print paper trick, by resetting pistons to zero and putting tape exactly on the place where it rubs rotor then then squeezing pads, then removing tape and squeezing pads again this will bias pistons around rotor.
Good-luck I once spent 3 days bleeding campy just to realize it sucks air in past the seal when you pull and squeeze lever.
They don't tell you that by getting rid of air in reservoirs you introduce air in the line which you get rid of by push/pull...
Campy always was a bitch to setup with its 0.0005 tolerances, I’m still to this day have no idea how to setup front derailleur, if you follow their videos it rubs the crank.
