F8 vs F10 Tire clearance
Stendhal
by Stendhal
nm
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
Stendhal
by Stendhal
Stendhal wrote:
Wed May 29, 2019 7:59 am
I owned both bikes in succession (coincidentally, the F10 was a warranty replacement for the F8 and I only paid the difference in list price). I did not see a difference in tire clearance, and I switched to a Tarmac SL6 to gain a wider clearance. Good luck!
Stendhal
by Stendhal
double post doubleplusungood
Joroz002
by Joroz002
To add to this discussion. I recently built an F8 disc and encountered issues with the tire rubbing on the brake bridge area. I was using 25 mm GP4000's on a 19mm internal width rim. I switched to 25mm GP5000 tubeless tires and the problem was solved. The new tire has a height at least 1.5mm lower.
Comparison
Comparison
