Shimano Part Number
ParisCarbon
by ParisCarbon
Does anyone know the PN for the little 2mm reservoir caps on the 9170 levers.. conveniently mine seems stripped..
MoreRideTime
by MoreRideTime
I believe you are after the “Bleed Screw & O-ring” which is part # Y0C698030.
Here is the exploded view diagram for you: http://si.shimano.com/pdfs/ev/EV-ST-R9170-4079.pdf
Squashednuts
by Squashednuts
What @MoreRideTime said
Also check out below thread
https://weightweenies.starbike.com/foru ... 3&t=146884
Fuji SL 5.8kg - viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
ParisCarbon
by ParisCarbon
Thanks guys... just ordered from SJS... those things are so soft.. gaaaaaarrrrbbbbbaaaaggggeee.....
sharkman
by sharkman
they are! (metal too soft) but so are most of the hex tools used to work on them. Don’t use low quality and/or heavily used keys (pb swiss for example is a good choice)
Verzonden vanaf mijn iPhone met Tapatalk
ms6073
by ms6073
Seeing as several in the other thread resolved issues with stripped bleed screws by tapping in a torx bit, seems like Shimano could solve a lot of problems by adopting torx for applications like this.
